Author Topic: GT-100 - Loop bit rate  (Read 270 times)
Offline srodders
« on: January 31, 2017, 02:08:59 PM »
Does anyone know what bit rate the built in loop of the GT-100 records at?
I'm looking at getting an external pedal and have it between two options. The RC-3 records at 16 bit and the TC electronics Ditto records at 24 bit. Some say the 16 bit of the RC-3 is a minus factor as it affects the sound quality. I want to compare paper spec with the GT-100 as I think that sounds quite woolly and if that is 16 bit then I will go for the Ditto.
Thanks.
« Last Edit: January 31, 2017, 02:14:51 PM by Elantric »
Offline Elantric
Re: GT-100 - Loop bit rate
« Reply #1 on: January 31, 2017, 02:15:12 PM »
I believe GT-100 looper is 16 bit, same as all current production Roland Loopers (sadly)
« Last Edit: January 31, 2017, 02:28:48 PM by Elantric »
Offline srodders
« Reply #2 on: January 31, 2017, 02:22:31 PM »
Thanks Elantric, have you compared the RC-3 with the GT-100 looper by any chance?
I consider the sound quality of the GT-100 looper not good enough for what I want.
Offline Elantric
« Reply #3 on: January 31, 2017, 02:24:15 PM »
Same here
I find the Looper in the Pigtronix Infinity to be cleaner, more dynamic range and stereo
Offline gumtown
« Reply #4 on: January 31, 2017, 02:49:58 PM »
All I can find on the GT-100 spec is
AD Conversion                 24 bits + AF method (*1)
DA Conversion                 24 bits
Sampling Rate                 44.1 kHz
Offline Elantric
« Reply #5 on: January 31, 2017, 03:13:12 PM »
Thats true for the GT-100 as USB Audio Interface specs   - latest firmware 2.10 now offers 24 bit@ 96kHz Mode- but internally GT-100 DSP's remains 44.1kHz
https://www.boss.info/global/products/gt-100/downloads/
The Looping function is a separate internal audio path which is 16 bit.
« Last Edit: January 31, 2017, 03:18:09 PM by Elantric »
Offline srodders
« Reply #6 on: February 01, 2017, 01:55:50 PM »
Actually found a review of someone who owned a Ditto, but wasn't happy with it so bought an RC-3 and reckoned the RC-3 was better. Think that may be where the money may be going.
