Author Topic: GT-100 - Patches have no sound?  (Read 385 times)
Offline satch1970
« on: January 24, 2017, 06:42:18 PM »
I downloaded a bunch of patches and imported the tsl file into ToneStudio. All the patches are listed but none of them have sound? I checked all the settings, input/output is correct, exp pedal to the floor still no sound? Other patches I loaded work fine not sure what I am missing? Any help greatly appreciated.
« Last Edit: February 13, 2017, 05:31:01 PM by admsustainiac »
Offline satch1970
Re: GT-100 - Patches have no sound?
« Reply #1 on: February 13, 2017, 05:28:57 PM »
Figured it out. The patches that I loaded into my GT-100 had the FV level set to 0. Just go into effects and edit the FV and change the level from 0.
« Last Edit: February 13, 2017, 05:31:08 PM by admsustainiac »
Online gumtown
« Reply #2 on: February 13, 2017, 06:35:43 PM »
Saved patches will save the position the EXP pedal is in at the time,
so if the EXP/FV pedal is right back (heel down) and saved, there is no volume.
but if you change a setting in your GT-100 system/global pedal settings for "Assign Hold = on"
then the saved pedal position does not matter as the position currently of the EXP pedal takes over from patch to patch.
This saves on having volume drop outs or differences on patch change.
Offline satch1970
« Reply #3 on: February 15, 2017, 06:46:14 AM »
Thanks gumtown this is great for all to know.
Offline joakes
« Reply #4 on: June 11, 2017, 02:10:17 PM »
Yes, but it doesn't work in every case. I had to change the FV values for each patch.
Just saying.
J
