Author Topic: GT-100 Firmware update 2.10  (Read 2692 times)
Offline gumtown
« on: January 04, 2017, 01:47:52 PM »
I only just noticed this in the GT-100 downloads page today.
SYSTEM UPDATE 2.10
https://www.boss.info/us/support/by_product/gt-100/updates_drivers/
https://www.boss.info/us/support/by_product/gt-100/updates_drivers/7172d7ae-7c14-4ab0-a105-d8faba48d4a0/
Update history
[ Version 2.10 ]
 Functionality Improvements
•Periodic sending of MIDI pitch bend sensitivity was stopped.
•Support for GT-100 Driver Ver.2.1 was added.
 GT-001 Driver Ver.2.1 has been provided with a function for switching the sampling rate.
 * Use the GT-100 Ver.2.10 in combination with GT-001 Driver Ver.2.1.
[ Ver.2.03 ]
 Bug Fixes
 The following bugs were fixed. •When PREAMP was set to a specific value, the sound sometimes did not play as set.
•Changes made in BOSS TONE STUDIO were sometimes not applied correctly on the GT-100.
•MIDI System Exclusive messages were sometimes not received correctly.
[ Ver.2.02 ]
 Bug Fix
 The following bug was fixed. •Inconsistencies in some parameter values occur when using BOSS TONE STUDIO for GT.
[ Ver.2.01 ]
 Bug Fix
 The following bug was fixed. •A problem in which edits made to GT-100 Ver.2 failed to be applied to BOSS TONE STUDIO for GT was corrected.
« Last Edit: January 04, 2017, 01:49:48 PM by Elantric »
Offline roachone
Re: GT-100 Firmware update 2.10
« Reply #1 on: January 04, 2017, 08:22:25 PM »
Wow! I'm really shocked that they are still doing updates for the Gt 100. Must not be a newer one coming for a while.
Offline aliensporebomb
« Reply #2 on: January 06, 2017, 08:18:17 AM »
I'm actually shocked too.  I wonder if an A-B comparison could be made across the patches from the previous version that someone might notice.
« Last Edit: January 06, 2017, 08:57:17 AM by aliensporebomb »
Offline gumtown
« Reply #3 on: January 08, 2017, 05:31:04 AM »
Just found the new GT-100 version 2.1 USB drivers posted on the Boss site too.
Update the firmware first before trying to load in the new USB drivers,
or else during the USB driver install you will get the message "gt-100 not found".
Offline wkcchampion
« Reply #4 on: January 08, 2017, 05:53:17 AM »
Thanks for the heads-up!
I will update the firmware soon, as I currently have the 2.03 version.
Offline tbeltrans
« Reply #5 on: January 08, 2017, 12:19:12 PM »
I was able to download the 2.10 firmware and update my GT-100, but I still don't see the 2.1 USB driver on the site.  Where is it?
I am looking at: www.boss.info/us/support/by_product/gt-100/updates_drivers/
Thanks,
Tony
Offline tbeltrans
« Reply #7 on: January 08, 2017, 04:10:43 PM »
Thanks!!!
Tony
Offline satch1970
« Reply #8 on: January 23, 2017, 05:43:34 PM »
I am currently running Version 2.03. Everything seems to be running fine. Do I need to update to the latest firmware update? I don't want to break what is working. Thanks  :)
Offline gumtown
« Reply #9 on: January 23, 2017, 06:15:43 PM »
It is not an essential update, the firmware update process is quite fool-proof these days too (on modern equipment with a separate boot loader like recent Boss/Roland gear).
It is useful for recording and re-amping where the sampling rate can be up to 96kHz.
I would suspect eventually an update will be required as future drivers for newer operating system will use the latest firmware driver.
The old (current) driver is not compatible with the latest firmware.
Offline ClaudioCas
« Reply #10 on: January 27, 2017, 09:44:55 AM »
Dear all,
I upgrade my Boss Gt 100 from 2.03 to 2.10 system version. I update to support the other sampling rate other than 44.1khz.
The upgrade was ok, but I cannot install driver 2.1 on my Windows 7 Sp1 64bit.
When I plug the gt-100 the driver installation fail due to Unsigned Driver reason. Seems that Roland/Boss fogot to sign the driver in tha package.
I have 2 pc with Win7 64bit and both make the same issue.
With an old netbook with Windows 7 32bit works without problem.
I use f8 at pc startup and start windows without driver signature enforcement and the Gt100 works, but this cannot be the final solution...
Any suggestions?
Thanks in advice
Online admsustainiac
« Reply #11 on: January 27, 2017, 09:58:20 AM »
Follow all instructions in the "README.htm" located inside the USB driver download.
https://www.boss.info/global/support/by_product/gt-100/updates_drivers/b0d53cff-b0c5-45ee-a271-7cf9fafa3218/
