Author Topic: Alternative for VB/VG99 plate mount  (Read 540 times)
Offline fokof
« on: September 10, 2016, 01:02:13 PM »
An alternative to the Roland part is that one from Alesis:
http://www.alesis.com/products/view/module-mount
Exact same size as the Roland , plastic , but only 15$
Offline Elantric
Re: Alternative for VB/VG99 plate mount
« Reply #1 on: September 10, 2016, 01:13:57 PM »
The APC-33 clamp is basically identical to the the top portion of the PDS-10, with universal clamp
The Roland VDrum units share the same mounting bolt pattern as VG-99 / VB-99
http://www.vguitarforums.com/smf/index.php?topic=757.msg16671#msg16671
More here
http://www.vguitarforums.com/smf/index.php?topic=1078.msg5480#msg5480
« Last Edit: September 10, 2016, 01:21:49 PM by Elantric »
Offline rolandvg99
  • Senior Member
  • Total likes: 114
  • Rating: 49
  • Roland VG-99, my favourite therapist.
« Reply #2 on: September 10, 2016, 01:18:32 PM »
I've got my VG-99 mounted to this one. 1U sliding rack shelf
Had to drill some holes, but my VG is safe and roadready.
« Last Edit: September 10, 2016, 01:24:42 PM by rolandvg99 »
My little Soundcloud corner
Offline Elantric
« Reply #3 on: September 10, 2016, 01:27:59 PM »
That's the best method above and is superior to the official RAD-99 rack mount adapter
Offline chrish
« Reply #4 on: September 10, 2016, 02:28:29 PM »
I'm still looking for a rad-99.  Only want it so it adds to the control panel effect so i can play starship. :-)
When i finally gig again, i think a padded hard case and a stand would work well for a guitarist that enjoys a chair while playing. I don't need to stand and play rock star like i used to.
« Last Edit: September 10, 2016, 02:48:58 PM by chrish »
Offline rolandvg99
  • Senior Member
  • Total likes: 114
  • Rating: 49
« Reply #5 on: September 10, 2016, 02:55:08 PM »
My VG-99 is a part of my mobile recording rig. That's why I've mounted it in a 6 unit rack with my Motu 8M and a MacMini Server. My other devices are mounted in two 2 unit rack cases. One with an Art S8 2-way splitter and extra 4 channels of headphone amping and the other with a Motu 828 MKIII FireWire and an ADA8000. I also bring my Yamaha 01V96 which is mounted in a SKB popup-rack when the situation calls for some FOH/Monitor mixing. I then stack them in two piles on a K&M 18950 Keyboard table-stand capable of loads up to 175 lbs. The stand leaves the floor area very open to add my FC-300, GP-10, SY-300 and other floor related units without too many obstacles.
Offline chrish
« Reply #6 on: September 10, 2016, 05:25:34 PM »
Altomusic is (or was?) taking orders for refurbished roland PDS-10 stands with the plate for $99.
