Author Topic: GK cable is noisy as hell  (Read 666 times)
Offline TINLEY
  • Lurker
  • Total likes: 1
  • Rating: 0
  • The Sampling Champion Of The Universe
« on: March 19, 2016, 02:04:07 PM »
I have a piezo bridge in one of my guitars and tried to connect it to the VG99 using a GHOST Hexpander
The noise was horrendous and made the whole thing totally unusable
so I made a link box up which takes the piezo direct into a 13 pin socket
same deal
I have an 8 pin MINI DIN out on my guitar (s) so I made an adapter which connects an 8 pin MINI DIN socket direct to the 13 pin input
NO NOISE
in fact it is so quiet I thought it wasn't connected till I hit the strings
so is there any issue with connecting a PIEZO direct to the VG99 rather than via a pre-amp?
I think the +7V supply being carried down the wire is not clean unless it gets grounded?
if the +7v is left open circuit - or maybe PIN9? then I think it bleeds into the guitar signal as hum?
anyone else got any thoughts on this?
thanks
Mark
Online Elantric
Re: GK cable is noisy as hell
« Reply #1 on: March 19, 2016, 03:31:14 PM »
« Last Edit: March 21, 2016, 02:52:26 PM by Elantric »
Offline TINLEY
  • Lurker
  • Total likes: 1
  • Rating: 0
« Reply #2 on: March 19, 2016, 06:16:08 PM »
Thanks I will give that a try
I have more than one cable with this problem
The 13 pin plug I just wired with ONLY 1, 2, 3, 4, 5, 6 does not have this problem
Is there any disadvantage in connecting the PIEZO direct to pin 1, 2, 3, 4, 5, 6 ?
The levels seem sane enough and it actually sounds better than it did through the HEXPANDER
Mark
Online Elantric
« Reply #3 on: March 19, 2016, 06:19:17 PM »
if it works for you - Go for it
And know it's lucky you are using piezo saddles which can function passively without a preamp ( typical characteristic reserved for LR Baggs Piezo saddles)
« Last Edit: March 21, 2016, 02:53:16 PM by Elantric »
Offline vanceg
« Reply #4 on: March 19, 2016, 09:12:46 PM »
Of the 30+ Ghost Hexpander installs I've seen, 60% or more suffer from HORRIBLE noise problems.  Often traceable to the Hexpander card or the connection between the hexpander card and the main Ghost card.  I no longer use the Ghost system for this reason.   If you have a good one, they are really pretty nice...but I don't count on buying a good one....
same deal
NO NOISE
thanks
Mark
Offline copperfrog
« Reply #5 on: March 20, 2016, 09:50:41 AM »
when i finished my install i got noise as well, it was from the magnetic pickup jack touching the metal of the jack plate which went away after i crafted a piece of wood coaster and replace it
i believe the ghost website suggest wrapping the boards in elect tape and making sure nothing touching any grounding paint or shielding from pickguard but can be a tight fit
 i once bought a brian moore gk guitar that had noise that went away after i removed the washer from the volume knob and made direct contact with the grounding paint-is that safe? i don't know :'(
vg99 boss gp10 tripleplay live3 digitech harmonyman
Offline TINLEY
  • Lurker
  • Total likes: 1
  • Rating: 0
« Reply #6 on: March 21, 2016, 08:41:00 AM »
Go for it
And know it's lucky you are using piezo saddles which can function passively without a preamp ( typical characteristic of LR Baggs Piezo saddles)
Okay thanks - I do have a GK3 but this whole sticking it in place with double sided foam is idiotic - and the adjustment of the arc with a screw which really shouldn't be anywhere near things that get hit hard etc
Every time I pick the guitar up to play it - it sounds completely different
I just liked the idea of having a benchmark and now I realise there isn't one ;/)
