Author Topic: BOSS GT-001 (blank patch)  (Read 1052 times)
Offline brockdavisson
« on: February 10, 2016, 06:58:40 PM »
Does anyone out there have a blank template to use for the gt-001.. Something we can load up and it has no amps/effects or anything going on, just a clean slate to start from? :D
A dwarf in a wheelchair on a mission through the music galaxy.
Offline Elantric
Re: BOSS GT-001 (blank patch)
« Reply #1 on: February 10, 2016, 07:05:36 PM »
http://www.bossus.com/blog/2014/03/11/new-boss-gt-001-guitar-effects-processor/
If you want to create a patch from scratch you can use the [WRITE] utility screen and navigate to the Initialize menu and initialize the patch. This turns everything most of the effects off and sets the PrA and PrB to a stock setting. Then from that point you can select an effect block (PrA and PrB are also considered effects blocks for sake of semblance) of your choice and turn it on and dial in the effect.
« Last Edit: February 10, 2016, 07:11:20 PM by Elantric »
« Reply #2 on: February 10, 2016, 07:19:51 PM »
Thanks, I'll give it a look.
