Author Topic: GT-100 - Windows 10 USB Driver  (Read 7271 times)
Offline Elantric
« on: August 07, 2015, 08:53:51 AM »
Don't Upgrade to Windows 10 unless you want a 2 month vacation from making music.
http://www.vguitarforums.com/smf/index.php?topic=9763.msg112488#msg112488
« Last Edit: August 07, 2015, 08:58:46 AM by Elantric »
Offline neskob
Re: GT-100 - Windows 10 USB Driver
« Reply #1 on: August 11, 2015, 05:18:37 AM »
I did this with my GT 001, and it works like a charm  :)
Open RDIF1148.INF in a text editor...
Change the following lines from:
[Roland.NTx86.6.2]
;; Windows8
%RDID0148DeviceDesc%=RDID0148Install, USB\VID_0582&PID_0187 ; GT-001
[Roland.NTx86.7]
;; not supported
To
[Roland.NTx86.6.2]
;; Windows8
[Roland.NTx86.7]
;; Windows 10
Offline Jim Williams
« Reply #2 on: August 11, 2015, 07:14:37 AM »
It seems you might have something and similar edits might work for your other Roland drivers. Did you alter the installers and reinstall or did you edit the files in the RDdrv001 directory?
Skype: (upon Request)
Offline neskob
« Reply #3 on: August 11, 2015, 11:37:24 AM »
I just uninstalled all Roland drivers which were partially installed (Win 8.1), then altered INF file (from Win 8.1 32 bit installation folder) like i wrote earlier, hit Setup.exe and hey presto! It works, at least for my GT 001.
Offline ivor-honda
« Reply #4 on: August 19, 2015, 08:45:03 AM »
I don’t believe it! I did what neskop said and it worked.
I have just updated Window7 to Windows 10 and then tried to load Boss Tone Studio but it said it couldn’t find the drivers, so I thought I would just reload the drivers and I would be good to go, but no. As soon as the driver started loading you are asked to connect the USB and switch the GT100 on, I did that and it just sits there doing nothing. So I uninstalled and tried again but still the same.
I then saw neskop post so I thought I would give it a go, there are some minor differences as I am using a GT100 instead of a GT001, the file name is different ie RDIF1149.INF not RDIF1148.INF, but I did what he said and I then successfully loaded the drivers and I can now use Boss Tone Studio on Windows10.
Thank you neskop.
Offline Mediaman
« Reply #5 on: August 20, 2015, 03:39:41 PM »
...there are some minor differences as I am using a GT100 instead of a GT001, the file name is different ie RDIF1149.INF not RDIF1148.INF, but I did what he said and I then successfully loaded the drivers and I can now use Boss Tone Studio on Windows10.
Wow. This was key to making at lot of Gt-100 people happy. Thanks so much for these posts!
I added a tutorial page to the ready reference site, for the benefit of GT-100 users, here :
http://gt100.mediamanhost.com/w10-driver-workaround.html
« Last Edit: August 20, 2015, 03:44:40 PM by Mediaman »
GT-100 Ready Reference Page : http://gt100.mediamanhost.com
TRIO Ready Reference Page : http://trio.mediamanhost.com
Offline neskob
« Reply #6 on: August 22, 2015, 09:04:50 AM »
I'm glad I could help Boss bros  ;D
Offline CBHScott
« Reply #7 on: August 23, 2015, 09:24:46 AM »
Thanks for the info. I was wondering about this, as I have a GT-001 incoming  :)
Offline ivor-honda
« Reply #8 on: August 25, 2015, 05:40:53 AM »
Just a quick update, I was also having a similar problem with my Edirol UM-2 USB midi interface, so I did the same thing, downloaded the drivers for Windows 8.1, altered the .inf file as Neskop suggested, deleted the old drivers, installed the “modified” driver and now the Edirol is working as well.
Thanks again Neskop, I would have never done it without you.
Offline Riff1964
« Reply #9 on: August 27, 2015, 05:00:44 PM »
I had upgraded to Windows 10 without checking driver availability .... duhhhh
I have followed these instructions - no success - decided to wait for BOSS to catchup.
Offline Godlike
« Reply #10 on: September 02, 2015, 05:55:37 AM »
Hi guitar Fans!!
So, to change the .inf file is work for me, BUT:
When i install the modified driver, the windows does'nt install it because:"The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering."
This is the solution:
You need to disable device driver signing check!
For this, please to do:
1. Select the “Start” button.
2. Type “startup”.
3. Select “Change advanced startup settings“.
4. Select “Restart now” under the “Advanced startup” area.
5. Select “Troubleshoot“.
6. Select “Advanced Options“.
7. Select “Startup Options“.
8. Select “Restart“.
When a menu will appear where you can press “7” on your keyboard to choose “Disable driver signing enforcement“.
And that's it! Now you can istall the driver....
This is the link:http://www.technipages.com/enable-disable-device-driver-signing
..and for now my GT-001 is really working under windows 10 x64!
Thank you!
Godlike
« Last Edit: September 02, 2015, 06:00:58 AM by Godlike »
« Reply #11 on: September 02, 2015, 01:20:13 PM »
Here is a better idea, don't mess with anything. they have the GR-55 and the GP-10 drivers and the rest can't be far behind. Be patient and don't brick your PC.
Offline Mediaman
« Reply #12 on: September 11, 2015, 11:11:06 AM »
Windows 10 drivers for GT-100 are now available here:
http://www.boss.info/support/by_product/gt-100/updates_drivers/350862
Also noted at bottom of status page here:
http://www.roland.com/support/support_news/2849
Links  have also been added to the ready reference page here:
Offline Elantric
« Reply #13 on: September 11, 2015, 11:14:02 AM »
So that leaves the VG-99 and GT-10 "orphaned" without USB drivers for current version of Windows
Offline Riff1964
« Reply #14 on: September 12, 2015, 01:52:46 PM »
Hoorahhh!!!
Auto driver update did not work, bit of fiddling inside the device manager and it is done ....
Offline Elantric
« Reply #15 on: January 31, 2017, 03:25:23 PM »
Get latest GT-100 Drivers / Firmware here
Latest firmware 2.10 now offers 24 bit@ 96kHz Mode- but internally GT-100 DSP's remains 44.1kHz
https://www.boss.info/global/products/gt-100/downloads/
