Author Topic: GT-100 - Dual Rectifier tone  (Read 1949 times)
Offline macman70
« on: July 28, 2015, 04:52:22 AM »
Here is a tone i threw together on the GT100, seems to work well for the Black Album sound. I will post the patch a bit later today for those interested, it is two modern rectifiers in a stereo chain in the GT100. I am not always a fan of a stereo chain like that but i find if you keep the recorded track dead center in the mix it works pretty good. I did two take of the riff and had them dead center in mix on this. Used an Ibanez RG1xxv bridge humbucker position.
Here is a small sound clip attached.
« Last Edit: June 02, 2016, 09:40:52 PM by Elantric »
Offline macman70
Re: Dual Rectifier tone
« Reply #1 on: February 17, 2016, 06:27:11 PM »
I am sorry guys, life got in the way of things.
Here is the patch.
Offline roachone
« Reply #2 on: February 21, 2016, 06:40:09 PM »
That's a killer patch! Thanks very much.
Offline Metaphasic
Re: GT-100 - Dual Rectifier tone
« Reply #3 on: August 07, 2016, 04:20:00 PM »
Nice patch. I tested this out yesterday to compare to mine. I usually run single / stereo though.
I know this thread is more than 10 days old, but I have something to mention about this patch.
I noticed you are using a no-drive OD/DS module to cause stereo imaging. But doing this means you can't use the OD/DS as a clean boost for leads. Try moving it back out in front of the two channels, then going into the channel mixer, setting the separation value from 0 to 1. Basically, it's a 1 millisecond delay, not enough to hear, but enough to create a more realistic stereo image.
Anyway, nicely done.
