Author Topic: GT100 - recording and triggering samples with MIDI  (Read 1811 times)
Offline nervoteso
« on: November 10, 2014, 03:25:15 AM »
does anyone know if i can use gt100 with ipad or a pc using guitar to midi conversion? i mean using sinth and piano from garageband or studio one etc.
« Last Edit: May 01, 2015, 11:12:57 AM by Elantric »
Offline gumtown
Re: GT100 - recording and triggering samples with MIDI
« Reply #1 on: November 10, 2014, 04:14:06 AM »
Yes, but only monophonic (one string at a time), for PC you need either USB driver installed or a USB/Midi device.
For iPad, you will need the camera connection kit and a USB <> MIDI Cable, there is no USB driver for IOS iPad.
« Last Edit: May 01, 2015, 11:13:33 AM by Elantric »
Offline nervoteso
« Reply #2 on: November 10, 2014, 05:07:56 AM »
so i can't play chords??
Online Elantric
« Reply #3 on: November 10, 2014, 11:22:01 AM »
Correct!
For iPad, you will need the camera connection kit and a USB device, there is no USB driver for IOS iPad.
Since none of the other Boss / Roland units have functional USB Class Compliant "MIDI over USB" -you will need a separate USB to 5pin DIN MIDI cable which is USB Class Complaint  required for use with the iPad
« Last Edit: June 10, 2016, 09:59:52 AM by Elantric »
Offline modalmojo
« Reply #4 on: December 27, 2014, 07:25:53 PM »
Gentlemen,
How's the guitar to midi monophonic tracking?  Is it on par with Boss GP-10?
I am interested in getting GT-001, so I suppose the midi functionality is identical to GT-100.
Thanks in advance.
Offline FarleyUK
« Reply #5 on: June 10, 2016, 04:19:17 AM »
Hi all,
I've started up a 3-piece band, and want to record and trigger guitar samples (i.e. backing chords during the solos) using the GT100. I've never ever tried this before, so am a total noob - can anyone please point me in the direction of what I would need to get in order to do this on the GT100?
I am already using the MIDI to link to a JVM when switching channels.
Thank you!
Online Elantric
« Reply #6 on: June 10, 2016, 08:46:43 AM »
On GT-001 / GT-100 Rev2 You can only trigger one note at a time over MIDI
You need a hex PU and 13 pin cable into a Roland /Boss processor that support Guitar to MIDI with GK 13 pin input to get chords to play on a External MIDI Tone Module.
Search YouTube
"GT-100 Guitar to MIDI
or
"GT-001 Guitar to MIDI"
! No longer available
Quick Look At Boss Gt-100 V2 Guitar to Midi Addition.
« Last Edit: June 10, 2016, 09:57:49 AM by Elantric »
Online shawnb
« Reply #7 on: June 10, 2016, 10:04:50 AM »
This is a broad topic, actually.  There are many ways you can go...
If you're looking for backing tracks, a looper may be more appropriate.  I'd start off by watching videos of various loopers discussed here.  One example in actin (watch the whole vid for an excellent lesson):
If you really wanted to trigger samples by midi notes generated from your guitar you'd need (a) something to generate the midi notes (sounds like the GT-100 does this) and (b) something to play them - such as Ableton Live's session view or Reaper/Playtime.  There was a project called Thinkplay recently that did this with the FTP.  In this mode, you're talking about bring a DAW with you, more like an EDM DJ:
« Last Edit: June 10, 2016, 10:14:31 AM by shawnb »
Address the process rather than the outcome.  Then, the outcome becomes more likely.   - Fripp
