Author Topic: DR_JONESS -QuadBoard GKP-4 clone - $79 - options, GK S1/S2 features and more....  (Read 2779 times)
Offline drjoness2001
OK!
Inspired my an email from Bill Ruppert who was looking for a simple GKP-4 clone, introducing the QuadBoard GKP-4 clone, $79 plus $5 shipping (in the US). Available now.
full details:
http://www.joness.com/gr300/quadboard.htm
The unit has two potential users: people who just want a simple, no frills 1 input, 4 output Roland GKP-4 clone.
Or, the DIY do-it-yourself user. The unit is designed to make it easy to modify and expand with GK S1/S2 independent switching, mute outputs, and more. Potentially, the QuadBoard can be configured as a super Roland US-40. That is, one input, four outputs, with complete control over all GK parameters, including independent volume and mute controls.
Check out the website link for PCB layout details, schematics, and more. I tested the unit with a GK-3 guitar and a (RMC) Godin LGX-SA, along with the Boss GP-10, Roland GR-55, VG-99, GI-10 and the RC-1324-VR.
If you have any other questions, email me at my website address: wayne@joness.com
Thanks for having a look! Wayne
« Last Edit: March 18, 2015, 04:21:02 PM by admsustainiac »
Offline cell7
I want one! What would it cost to get it to the Netherlands?
Offline CodeSmart
  • Senior Member
  • Total likes: 400
  • Rating: 53
  • Trying to stay healthy and learn about electronics
Very nice Wayne, as always.
You've also made a great web page and video for your product. I know how much time and effort these things take.
Got more gear than I need...and I like it!
Offline billbax
Congrats to you Wayne and your latest.  Nice looking board there.
Bill
I can ship USPS Priority Mail Flat Rate box for $24.75.
I can also probably ship the unit first class, but I'll need to check on the size of the box.
Wayne
First-class shipping to the Netherlands is $14.90. Email me at wayne@joness.com, and I can send you a PayPal invoice. Thanks! Wayne
Offline highlandsrock
Got my Quadboard here in the UK last Saturday. Thank you Wayne for shipping it out so promptly. Took 1 week to get over from the States. Total cost in sterling incl. shipping using PayPal was £ 58.29. Much cheaper than the silly prices old GKP-4's are going for on eBay. Nicely finished PCB and easily expandable. Going to mount it in my 19" rack so just need to find the best way in drilling accurate 16mm holes through a blank steel panel and deciding which switching options to go for.
Godin Freeway SA, Ibanez RG870 and PRS SE Custom 24 both with GT3 internal kits, Ibanez 2402DX
GR-33, GR-55, GP-10, US-20, FC-300, KC350 x 2
Offline Elantric
Mine arrived as well.
Installing my QuadBoard in the rear panel of an old M-Audio Blackbox Footswitch chassis - then adding more foot switches
$29 +$15 shipping here:
http://www.ebay.com/itm/M-Audio-Blackbox-Pedal-Board-NEW-/321497391983?pt=LH_DefaultDomain_0&hash=item4adabce36f
« Last Edit: September 12, 2014, 04:35:10 PM by Elantric »
I use a UniBit for the 13-pin connector holes. On my UniBit, the hole size is 5/8", or 16 mm:
http://www.irwin.com/tools/browse/drill-bits/unibit-step-drills
Wow...that is a great idea. I don't know what kind of pot is in the M-Audio pedal, but I can imagine wiring that as an additional volume control.
If you can post photos, that would be great. I'm going to order one of those M-Audio pedals as well.
Mine arrived aswell.
(Image removed from quote.)
Offline Bill Ruppert
Holy smokes I missed this post!!!!!!!!!!!!!!
I ordered mine just now.
Cant wait, Dr Jones builds the coolest stuff!
OK!
Following Nigel's lead, I drilled out a single space 19" rack panel for make a rack-mount GKP-4!
More photos here:
http://www.joness.com/gr300/quadboard.htm#photosrack
You're ahead of me!. I'm now trying to work out what other options to fit.
Need to sit down in a quite room with pen and paper and draw up how I'd like my GR-55, GR-33 and GP-10 interface - audio/midi to my rack. Sounds like a good project for the winter months. Will need to make up some "snakes" to connect the various units to the "mothership". If only there was a good source of cheap, reliable 13 way cables in the UK
Offline Elantric
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xroland+gk+13+pin+cable&_nkw=roland+gk+13+pin+cable&_sacat=0
More photos here:
I'll install my QuadBoard upside down in my M-Audio Blackbox Footswitch chassis - - I need the Gk Guitar input on the right rear so and I intend to relocate the Gk Input over to the far right  rear side of the chassis and use custom jacks for (the +/-7VDC Power Input source) on both GK Input (to power the guitar) and the GK Out#1 ( which powers the Quadboard)  using  hardwired  DIN13 metal female "chassis mount style" jacks (for the complete 360 degree ground contact surface area for for each Gk 13 cable plug) - to tame GK 13 cable vibration noise on bouncing mobile stages near a drum riser) and mount both on isolated ground dielectric nylon/ plastic panels using Gumbo's SL13JS SynthLynx Jacks and nylon screws/nuts c, to maintain isolation between Analog Ground and Chassis Earth Ground
http://www.vguitarforums.com/smf/index.php?topic=8888.msg63875#msg63875
 and carefully verify my rig and pursue isolated Shells on the 13 pin GK Outputs #2,3,4   - to help tame ground loop noise  - which is the typical big problem for everyone using any 13 pin GK 4 port  parallel box.
But still thinking this through -
« Last Edit: September 13, 2014, 05:38:42 PM by Elantric »
Got my Quad board today.
Man its a thing of beauty.
Wayne is great!
Offline Elantric
Now you need this to get large holes in a metal chassis quickly and safely
Use caution and use a Vise!
3Pc-HighSpeed-Steel-Step-Drill-Bits-Set-28DrillingBit-Sizes-Harbor-Freight-Tools $9.00
http://www.ebay.com/itm/3Pc-HighSpeed-Steel-Step-Drill-Bits-Set-28DrillingBit-Sizes-Harbor-Freight-Tools-/151362231580?_trksid=p2054897.l4275
« Last Edit: September 15, 2014, 03:41:38 PM by Elantric »
Well, I checked out the M-Audio pedal. I looks great, but I cannot for the life of me figure out how to take it apart. I removed every exterior screw I could find, but the top did not want to release. I started to pull up the front, and noticed the metal was going to flex rather than move. So I stopped.
Unfortunately, I am back in classes right now, which has pretty much put a halt to any guitar synth stuff until after exams....Wayne
Offline Elantric
I have two M-Audio Blackbox Footswitch chassis - and hope to take one apart soon.
I believe the underside of the Top metalwork sides have an adhesive glue - so pry it apart carefully!
Vguitarforums member "tekrytor"  performed a Highly Liquid MIDI Foot controller mod in his
http://forum.highlyliquid.com/showthread.php?p=4861
« Last Edit: September 18, 2014, 12:45:41 PM by Elantric »
