Blackstar ID:Core Stereo 40 (2x20W) Stereo Combo
Started by Elantric, March 06, 2014, 09:12:10 AM
Issue was the EU mandated power saving auto off when 1/4" input not used -  probably still suffers same issue as old generation
pacemaker1000
So a replacement power supply would fix this ?
Or can you just put a dummy plug in guitar socket or does it have to see a signal?
No,
Its built in " green auto shutoff" in CPU Firmware - kills sound within 3 minutes unless the 1/4" jack is occupied with a dummy plug
pacemaker1000
Quote from: Elantric on January 27, 2024, 07:14:21 AMNo,
That's great info it will work as Frfr speaker with dummy plug
Does it allow the widespread audio through aux in?
Currently using a Fender GT40 but for some reason the aux in is routed through the guitar equaliser colouring the sound
Im testing now at NAMM  on headphones with IDCore V4 Stereo 20 playing for 7 minutes solid, no drop out feeding only Aux Input
pacemaker1000
Quote from: Elantric on January 27, 2024, 10:26:31 AMIm testing now at NAMM  on headphobes with IDCore V4 Stereo 20 playing for 7 minutes solid, no drop out feeding only Aux Inut
Opinions on new range?
Caparison to G40?
Quote from: pacemaker1000 on January 29, 2024, 02:56:47 AMOpinions on new range?
Caparison to G40?
Only G40 I know is an old Gibson G40 amp
This new ID Core has 90% same sound as prior IDCore. no mobile apps. No Bluetooth , No IR Cab Loading
IMHO The NUX Mighty Space is a smarter purchase imho
By spring 2024, there will be a Nux Mighty 40BT MK2 with many features, and FX Loop
pacemaker1000
Quote from: Elantric on January 29, 2024, 03:46:32 AMOnly G40 I know is an old Gibson G40 amp
Oops, I meant Fender GT40
I'll check out the Nux
