Author Topic: GT-100 - Boss Tone Studio for GT-100 / GT-001  (Read 8400 times)
Online Elantric
« on: January 23, 2014, 08:13:34 AM »
http://bosstonecentral.com
go to the 6minute mark and listen to Paul Youngblood's announcement of "BossTone Central" - where he implies that an online "ToneStudio" application will allow sharing of presets for multiple products. This might include the GR-55 eventually  - its implied, since the GR-55 is  featured on the Boss guitar site
Currently the Boss ME-80 is featured and nothing else.
« Last Edit: October 26, 2016, 06:18:43 PM by Elantric »
Offline papabuss
Re: Boss Tone Studio for GT-100 / GT-001
« Reply #1 on: January 23, 2014, 12:27:51 PM »
THX for the link! :)
Offline papabuss
« Reply #2 on: January 24, 2014, 03:11:16 PM »
BTW lots of nice interesting ME80 patches and a good start for creating new ones with the VG99 ... ;)
http://bosstonecentral.com/
Online Elantric
« Reply #3 on: March 11, 2014, 11:25:42 AM »
New updated section at Boss Tone Central for sharing Boss GT-100 V1 / V2 patches
http://bosstonecentral.com/liveset/category/gt/
New Boss GP-10 section at Boss Tone Central will be added soon.
Offline ngotruongphi
« Reply #4 on: October 12, 2014, 09:41:41 PM »
can some 1 help me plz , i download bosstonecentral , but cant run , only see that screen
Offline gumtown
« Reply #5 on: October 12, 2014, 10:24:15 PM »
It only runs if the GT-100/GT-001 is present and connected and has the correct USB drivers installed.
« Reply #6 on: October 12, 2014, 10:46:55 PM »
ya! it ready connected with my gt 100 , i can use with my wife's pc , but can't run with my notebook , plz help me :(
Online Elantric
« Reply #7 on: October 12, 2014, 11:33:29 PM »
Boss GT-001 Downloads
http://www.bossus.com/gear/productdetails.php?ProductId=1320
You must install Boss GT-001 software in this order:
1) Install the Boss GT-001 USB Driver
I suggest before proceeding, confirm the Boss  GT-001  USB Driver is correctly installed by connecting the Boss  GT-001  by USB and then look in the Windows Control Panel and open the Boss  GT-001  Control panel and verify you can adjust the  GT-001  latency buffer.
2 ) Install the Boss Tone Studio for  GT-001 (download from the Roland site)
One important aspect for Windows users - you must have a live Internet connection during the BOSS TONE STUDIO for  GT-001  software installation procedure
because midway thru the processes you must install Adobe Air.
You might have a clobbered Adobe AIR installation - suggest re-install it from this link here:
http://get.adobe.com/air/
« Last Edit: October 12, 2014, 11:36:59 PM by Elantric »
Offline gumtown
« Reply #8 on: October 13, 2014, 02:01:57 AM »
The Tone Studio shows a blank screen like that if it does not ''see'' the GT-100,
USB driver must be installed correctly, and your GT-100 must be running Firmware level 2 check version as follows
How to tell the version
Please check the version of the system working on your GT-100 before downloading the archive file.
1.Hold down [ EFFECT ] button and [ SYSTEM ] button, and press and hold POWER switch.
 The left display will show the current version number at "Ver."
2.Press and hold POWER switch to turn off the power.
*Don't perform the update if the product is already up-to-date.
latest version is 2.03
You must also be using the Version 2 USB drivers too.
Is your notebook running Windows 7/8/8.1 32 or 64 bit (full windows version) or is it a Surface or Rt version?
« Reply #9 on: October 14, 2014, 03:07:48 AM »
 :( :( :( :( my gt-100 v2.03 and use driver from boss , i can use GuitarFriendJam but cant run boss tone  :'( , my system : i5 CPU U470 , 4GB ram , window 7 64 - bit and GPU Ati HD 5450, i can run with my wife's old pc , with win xp :( when run with my notebook , only see screen like that picture , cant do anything  :'( :'(
Offline gumtown
« Reply #10 on: October 14, 2014, 04:49:22 AM »
When the Tone Studio editor installs, it usually also installs "Adobe Air" which is required to run tone studio.
Possible your install didn't allow the Adobe Air update via the interweb.
Also try GT-100FxFloorBoard patch editor
http://sourceforge.net/projects/fxfloorboard/
Offline TheBigSlip
« Reply #11 on: October 27, 2014, 08:34:57 AM »
Hi, I'm also experiencing this same problem.
I used to use the librarian when my GT-100 was running ver 1 f/w.
Earlier in the year I bought a new PC and used the new Ver3 driver and upgraded the GT-100.
But I've never been able to use Boss Tone Studio.
In order to try and fix this I recently upgraded the firmware to v2.03
I uninstalled the Ver2 driver and Adobe AIR and then reinstalled both.
Also reinstalled BOSS Tone.
My GT-100 is connected fine to the PC and works perfectly with Sonar or any other apps, but just has problems with BOSS Tone studio.
Interestingly if I do not connect the GT-100 then BOSS Tone will indicate it can't see the device.
I can then plug in and turn on the GT-100 and hit the refresh button on BOSS Tone and then it shows the GT-100 in the listed devices (along with the DAW control), but when I select the GT-100 the application goes dark and a flashing BOSS Tone icon pulses in the centre of the screen.
Left it for hours to see if it was synching but never times out.
My system is Win8.1
Also I tried loading the drivers, latest AIR and BOSS Tone onto a win7 laptop, and an old Vista PC.
But all 3 have exactly the same symptom!
Also tried different USB cables.
The common element hear is my GT-100, which is running the latest update and other than that appears to be working perfectly.
If anyone has any advice at all it would be much appreciated, this is driving me nuts!
Offline TheBigSlip
« Reply #12 on: October 27, 2014, 01:10:49 PM »
Hi, After checking all over the web and reading every manual and getting nowhere. I've finally managed to resolve the problem!
For anyone else having this issue:
On the GT-100 go to System / MIDI Settings.
On page 2 make sure MIDI in select is set to USB (Auto)
and make sure MIDI out select is set to USB
All springs into life!
Online Elantric
« Reply #13 on: December 12, 2014, 10:21:59 AM »
how can i load a patch in to the gt100,with the FX-Floorboard editor,how can y find the tone central patches
Its best to ask these questions on the GT-100 area.
I dont use one of those myself - but we have many others here who will be happy to help answer these questions
Look here for GT-100 Posts here:
http://www.vguitarforums.com/smf/index.php?board=148.0
http://www.vguitarforums.com/smf/index.php?board=149.0
http://www.vguitarforums.com/smf/index.php?board=150.0
« Last Edit: December 12, 2014, 10:24:37 AM by Elantric »
Online Elantric
« Reply #14 on: March 03, 2015, 12:18:36 AM »
Online Elantric
« Reply #15 on: June 25, 2015, 03:09:40 PM »
This doc should be helpful for all Boss Tone Studio Users ( GT-100 / GT-001 / GP-10 / ME-80 / RC-50)
Boss Tone Studio for SY-300 User Guide
http://www.vguitarforums.com/smf/index.php?topic=15397.msg109931#msg109931
Online Elantric
« Reply #16 on: March 16, 2016, 11:13:00 AM »
2016-03-16
BTS for GT-100 (Ver.1.1.0) software
*Update GT-100 to the latest program(Ver.1.1.0) to use BOSS TONE STUDIO for GT.
BTS for GT-001 (Ver.1.1.0) software
*Update GT-001 to the latest program(Ver.1.1.0) to use BOSS TONE STUDIO for GT.
Now there is a new Boss Tone Studio   "Offline Mode"  - for reviewing  patch settings without the actual hardware being present and connected!
Dont forget to read the new BTS for GT Owners Manual too:
http://cdn.roland.com/assets/media/pdf/BTS_GT_e03_W.pdf
« Last Edit: March 16, 2016, 11:27:54 AM by Elantric »
Online Elantric
Re: GT-100 - Boss Tone Studio for GT-100 / GT-001
« Reply #17 on: October 26, 2016, 06:15:21 PM »
BTS  for BOSS GT-100 EDIT Page
BTS  for BOSS GT-100 Control Assignment Page
« Last Edit: October 26, 2016, 06:18:56 PM by Elantric »
