Plus Pedal - Sustainer
Started by Elantric, January 19, 2017, 10:18:30 AM
We'll see, but "Real time audio sampling" claims to deliver "impossible" arrangements
NAMM 2017: The showfloor doors haven't even opened yet as we write, so whisper it, but if it can deliver on its promises, the PLUS could be this year's breakout pedal at NAMM.
Incorporating patent-pending sampling tech that turns the second half of any note into a seamless, continuous loop - and can handle up to five layers simultaneously - it certainly seems like the PLUS Pedal could indeed, as creator Ilya Krumins claims, bridge the gap between rhythm and lead playing, as well as offering intriguing possibilities for much more than guitars.
If so, we'll be heading straight for their stand and, essentially, begging them to take our money. The PLUS Pedal is due to be available in June 2017, at an as yet undisclosed price.
In the meantime, check out the video demo above, or read on for more detail.
PLUS Pedal press release
What is the PLUS Pedal?: The PLUS pedal is a new kind of audio processing engine that offers piano-style sustain for electric guitars and all other melodic instruments. This is more than just a stompbox – it is a vast extension of your instrument that bridges the gap between rhythm and lead playing and lets players explore totally new territories.
Create "impossible" arrangements by playing lead lines on top of sustained chords, combine up to 5 different sounds to build deep multi-layered drones or use the WET only mode to give your instrument a totally new character.
The PLUS Pedal is available on pre order on www.pluspedal.com with a special early bird offer. The production will start in March 2017 and expected shipping date is June 2017.
How does it work?: The PLUS Pedal does not generate sounds with oscillators and filters! Instead – think of it as a sort of "Smart Looper" that only catches the second half of each note or chord you play and samples that short snippet of sound into a seamless, continuous loop.
This patent pending technology called "Real Time Audio Sampling" ensures that each sustained note or chord will retain the exact character of your instrument and your playing style.
This method is also fully responsive to any playing style - create continuous layers of sustain incorporating vibrato, bends, harmonics, trills and other dynamic playing techniques. You can also use the whammy bar, play with a slide or experiment with amp feedback or noises – the PLUS Pedal will capture all of these tonal nuances and turn them into a continuous sound.
The PLUS Pedal can also be used with all other acoustic instruments, such as brass or woodwinds, or even vocals. Use a standard microphone to produce amazing polyphony in real-time and create multiple voices like never before.
Key features
Full spectrum of sustain controls – 4 knobs (Blend, Sustain, Rise, Tail) allow to modify all parameters of the sustain tones
Multiple layers allow stacking up to 5 notes or chords simultaneously.
Unique design – a brilliant combination of a guitar stomp-box and piano's damper pedal. The steel case will make sure it lasts, and the classy look will make it fit on any stage, from café guitarist to rock band to jazz trio.
Two Outputs will allow you to use the PLUS with a two amplifier setup or split your effects chain.
Revolutionary FX Loop allows you to link the PLUS Pedal with any other effects unit and use it to modify the Wet or the Dry signal separately.
What is it for?: The PLUS Pedal is an extension of your instrument, allowing to create multiple layers on the go. From jazz-voiceleading to heavy post-rock drones – the Plus Pedal allows the guitarist to do more with the instrument! A useful tool in any context - live performances, songwriting & arrangement, creating drones, ambient soundscapes, cinematic sound effects, and much more.
It is also a fantastic tool for aural training and practicing improvisation. Instead of thinking aboutwhich scale shape fits over what changes – the PLUS Pedal focuses all of your attention on listening to the tonal relationships between the chord and the notes you play on top.
How is it different?
The PLUS Pedal is not a looper, nor a delay or a reverb pedal - it is a whole new type of effect based on real time sampling and looping.
Unlike synth-based units – the PLUS does not produce an annoying digital-sounding tone. The PLUS Pedal's Wet signal is built from short samples of your instrument's output, thus preserving the character of each note you play.
It is not just for guitars. The PLUS Pedal can be used with any melodic instrument, including saxophones, horns, trombones, violins, cellos and many more.
The PLUS Pedal features two outputs and a separate FX Loop which lets you create very interesting combinations of pedals.
About the team
The core team consists of three engineers/guitarists and the PLUS Pedal started out as a post- graduate experiment on sound synthesis. We instantly realized this idea's massive potential for live instruments, and began working on the first prototypes in early 2015. Today, almost two years later – with two new team-members, three full redesigns and thousands of work-hours under our belts – we are proud to announce the PLUS Pedal's debut at Winter NAMM 2017, with the first production batch already under way.
Playing and gigging with the PLUS pedal throughout development has completely changed our perception of the guitar and music-making in general. The PLUS Pedal truly lets you do more with your instrument, and judging by the smiling, excited faces of numerous local musicians that have helped us test the final product - I think we may have created one of the most exciting effects units of our generation!
ILYA KRUMINS, creator of the PLUS Pedal
Rhcole
I think when they claim that they are the first real sustain pedal for guitar, they actually mean the physical PEDAL ITSELF. Not the underlying freeze circuitry.
Oh. Now I geddit.
vanceg
Quote from: Rhcole on February 20, 2018, 06:35:49 PM
Oh. Now I geddit.
It does have some cool features that other freeze pedals don't have.  That said, I'm kind of interested in hearing what features people WANT in a freeze pedal as I've got "Write Polyphonic Freeze Algorithm for current DSP Platform" on my ToDo list....
Quote from: vanceg on February 20, 2018, 07:00:35 PM
...Hmmm...remind me to write to you about that sometime, Vance....   ::) :-*
The first thing would be stereo.
I don't know why there's not a freeze/sustain in stereo.
There's nowhere to add it to a signal chain of mine in mono.
vanceg
Quote from: Brak(E)man on February 20, 2018, 10:28:53 PM
THis one will be stereo.  Actually, it will start live as an Octaphonic version, then likely move to a stereo/mono version.
