RC-300 Firmware Version
Started by Tek, June 23, 2014, 09:31:43 PM
Tek
OK, this may be a silly question but...
I just got a new RC-300 and I checked the firmware version -
the window says "VER 1.10   REV 1840   VVER 1.01"
I thought the newest fw version was 1.05. What am I missing? Is there a version 1.10?
I Googled it and came up with no real answers. Although everything is working fine, I'm just curious. ???
Thanks in advance,
Tek
looper
Hi, see here
http://www.roland.com/support/article/?q=downloads&p=RC-300&id=62467493
RC-300 System Program Version 1.05
This program is used to update the RC-300 system software to the most recent version.
Products?RC-300
How to tell the version
Please check the version of the system working on your RC-300 before downloading the archive file.
Adjust MASTER [ LEVEL ] knob, TRACK [1] [2] [3] sliders, and RHYTHM [ LEVEL ] knob to minimum.
Hold down RHYTHM [ EDIT ] button and [ TAP TEMPO ] button, and switch on the power.
The left display will show the current version number at "Ver"
Turn RC-300 off after checking the version.
* Don't perform the update if the product is already up-to-date.
Update history
[ Version 1.05 ]
Bug Fixes
The following bugs Were fixed.
Some personal computers might not recognize the device connected with the USB 3.0 port.
Other USB equipments might not work when a personal computer rebooted with connecting the device via the USB 3.0 port.
When you save a phrase memory after recording in the specific procedures, it might save an unintended sound.
[ Version 1.03 ]
Bug Fixes
Some noises might occur on a USB Audio signal.
RC-300 might hang up when you switch an effect patch.
[ Version 1.02 ]
Bug Fix
The following bug is fixed.
RC-300 might stop working with the " Too Busy! " message on the display when it was switched from "REC" to "PLAY" on the "Memory:Single Tr Play=ON" setting.
What you will need to update your RC-300
RC-300
USB cable
A computer with a USB connector ( Windows 7 / Vista / XP, MacOS X )
Caution when performing the update
We recommend that you back your user data up before you perform the update. If a problem occurs and your user data is lost, you will be able to restore the original state by restoring the data you backed up. For details on the procedure, refer to the Owner's Manual.
Never apply this update data to any product other than the RC-300. This update data may destroy the data or system program of other products.
Never power-off your RC-300 while the update is in progress!
If a power failure or similar accident occurs during the update process, the RC-300 won't be able to start up in normal operating mode. This will require servicing, so you will need to contact Roland service center near you if this occurs.
We regret that we are unable to answer questions regarding the update procedure using this system program. Please perform the update responsibly, following the directions given in this document.
Getting the update file
Please open/extract the downloaded "rc300_sys_v105.zip" file on your computer to get the update files in the "rc300_sys_v105" folder.
Procedure for the update
Caution
You must not rename the extracted files.
Never turn off the RC-300's power while the update is in progress. Otherwise the system program or the RC-300 itself may be destroyed.
Please install the extracted system program files into your RC-300 according to the following procedure.
* Do not connect the RC-300 and the computer yet.
Hold down RHYTHM [ON/OFF] button and [TAP TEMPO] button and switch on the power.
The message "RC-300 Updater" will appear on the display.
Connect the computer to the RC-300's USB port by a USB cable.
The message "Connected." will appear on the display.
Open the BOSS_RC-300 icon.
With Windows 7 / Vista / XP
Within Computer (or My Computer), open "BOSS_RC-300".
* "Removable Disk ( * : ) " may appear instead of the BOSS_RC-300 icon.
With Mac OS
On the desktop, open the "BOSS_RC-300" icon.
Copy (drag and drop) all the files included in the "rc300_sys_v105" folder into the "BOSS_RC-300" icon.
* Do not copy the "rc300_sys_v105" folder.
Disconnect the BOSS_RC-300 from the computer.
Right-click on the "BOSS_RC-300" icon in My Computer (or the "Removable Disk ( * : ) " icon) and execute "Eject."
With Mac OS
Drag the "BOSS_RC-300" icon to the Trash icon in the Dock.
Disconnect the USB cable.
The message "[WRITE] to start" will appear on the display.
Press [ WRITE ] button to start the update process.
The message "Completed." will appear on the display when the update process completes.
Turn the RC-300 power off.
Please verify the version number with the procedure described in "How to tell the version" part of this document.
1.10?  Interesting.  I wonder if the Roland Japan site has that?  The last update was April of 2013 that I can see.  When did you buy your RC-300 and did you buy it new?
Looking at Roland Japan site:
http://www.roland.co.jp/support/article/?q=downloads&p=RC-300
1.05 is the last version according to the website.
1.10 - mysterious.
Tek
I purchased the unit new about a week and a half ago from Sweetwater (got a nice Gearfest price too ;D). From everything that I read, when you check the version, the firmware number will be on the left. My display reads, from left to right "VER 1.10   REV 1840   VVER 1.01". Exactly as written. I just thought it was funny that there was no info out there about a version 1.10.
QuoteI just thought it was funny that there was no info out there about a version 1.10.
With any luck Roland will post a download for RC300 FW1.10 soon.
Suggest check here once a week
Understand that most Roland Product Support people are prepping for the Summer NAMM show in Nashville July 19- its possible Roland might make an announcement regarding RC-300 FW 1.10 at Summer NAMM
https://www.vguitarforums.com/smf/index.php?topic=11386.msg82887#msg82887
QuoteI purchased the unit new about a week and a half ago from Sweetwater (got a nice Gearfest price too
Contact Sweetwater as they have a good rapport with Roland Product Specialists - and maybe they can reveal the facts  / updates that RC-300 FW1.10 addresses
Interesting.
Previous updates were 1.02, 1.03 and 1.05.  1.10 implies multiple fixes or additions.  :)
#6
Update: My own unit says:
Ver      Rev      Uver
1.05    1837    1.01
So 1.10 / 1840 / 1.01 definetely implies further work.  Interesting.
I wonder what differences are in your version versus mine?
I've emailed Boss USA on their facebook page and will let you know what I hear from them (if anything).
Tek
Quote from: aliensporebomb on July 02, 2014, 05:27:43 PM
Ver      Rev      Uver
1.05    1837    1.01
Not sure what the differences/ fixes are on the newer FW, but I'd be interested to know.
Thanks Aliensporebomb
They responded.  As expected, nobody seems to know, only Roland Japan:
Thanks for contacting us about this. Usually product revisions such as this eventually become available as free downloads. We know of no ETA for this to happen right now but if does it will be announced on our website and our Facebook page.
Tek
#9
Quote from: Elantric on July 02, 2014, 02:09:23 PM
Thanks Elantric, I may try that. I'll post any updates...
Tek
Quote from: aliensporebomb on July 02, 2014, 09:02:05 PM
Guess we just wait and see...
Thanks for trying to find out
Nothing new yet.  Curiouser and curiouser.
Syph
I know right?!
Been hoping this will fix my damn (once every six hours odd) freezing issues, but still nothing!
My Sweetwater guy called me - I left him a message back about this exchange - I'll post what he says when he calls me back.
Update:
After forwarding the pictures to my Roland rep, all I was able to find out is that it is "coming soon". He's not aware of what the firmware update will do. Sorry I do not have more information for you!
Syph
Major thanks for the update man! I was starting to wonder if this was a crazy glitch or nasty little photoshop prank...
Damn having hope. Nothing crueller than hope...
It's interesting: shipping units have the update but they're dragging their feet on releasing it on the website.  You have to wonder what the update does and maybe it is still being tested to make sure it doesn't brick existing units.
Tek
Just checking back in... My unit is working fine. I'm starting to get a little more comfortable with it and learning to use it a little more effectively. It's actually pretty simple, compared to months of digging through my GR-55.
Wish I could tell you what this new FW version is doing, but...
Also, no bricks here ;D...
(and Photoshop - that would be too cruel)
Syph
aliensporebomb- I have been wondering about that as well. I have been wondering how much change a firmware update could bring, but I keep coming back to bug fixes. There is other options like relabelling things like tempo/loop sync to make it less confusing, or (VERY unlikely) adding new features (FX, drum machine beats/sounds, expanding assignments, USB sound card upgrades). The work they did on the GT100 v2 was pretty cool and it would be neat to see something like that happen again, but I am not holding my breath! Hell, of late I have even been wondering if they would release a new flagship floor unit to match the RC505....
Tek- Thanks for bringing this update to our attention, would have had no idea it was even in the pipeline if it wasn't for you!
#20
I can think of a couple of potential issues that merit fixing or improving:
(1) this woman reported a problem over two years ago - I wonder if this still exists?  I'd need to set my RC300 up exactly the same as hers.  Her video has over 4000 views:
(2) the octave divider effect is pretty marginal - even my old Boss OC-2 was light years better.  Maybe they could improve it with existing hardware.  The following quote comes from a response to the video in problem one where someone mentions it:
@AxelMontaner Here is the Boss email response to the guitar>bass FX issue: "We have confirmed that our RC-300 in product support also produces intermittent results when using the Guitar-Bass effect. We have submitted this info to Boss Japan so that they can research it further."
I'm sure there are other things that could be added/improved.  The fact that we're going from version 1.05 to v1.10 when usual updates are .1 increments implies more than one "fix" or correction.
Still no 1.10.  This is worse than waiting for a VG-99 update that will never come.  It's waiting for an update that's out there in recently manufactured units but not available to those with existing units.
QuoteStill no 1.10.  This is worse than waiting for a VG-99 update that will never come.
Try asking this guy at link below - (supposed to be a real Roland Repair tech)
http://www.justanswer.com/sip/Roland
Oh man.  I'll wait.  To get an answer it requires $30 to those guys!
Syph
Any one interested in pitching in a few $?
If there are enough of us then it may not seem so harsh...
