midi and 13 pin connection
Started by wineman, May 15, 2012, 10:25:20 AM
wineman
Hi.
I just purchased a GR-20 and have it controlled by the VG via 5 pin connection.My question is,would the tracking be better if I hooked up a US-20 and A 13 pin to the GR-20,and just control the patch changes via midi,Thanks for any advice.
QuoteMy question is,would the tracking be better if I hooked up a US-20 and A 13 pin to the GR-20,and just control the patch changes via midi,Thanks for any advice.
Most folks experience faster tracking  / lower latency using a US-20 to feed the GR-20 directly with the 13 pin signal.
Using MIDI - between VG-99 MIDI Out and GR-20 MIDI In, you have too many multiple conversions which take time and add latency.
wineman
Thanks for confirming my suspicions.I appreciate your comment and will be off to buy those things I need,Thanks again.
