HyVibe - Smart Acoustic Guitar
Started by admin, December 19, 2017, 08:14:30 AM
http://hyvibe.audio
https://www.indiegogo.com/projects/hyvibe-the-world-s-first-smart-acoustic-guitar
  HyVibe Audio
Search ...
The HyVibe Guitar is Available on Indiegogo
Order Now!
Multi-Effects Processor
Self-amplify guitar effects such as chorus, reverb, distortion, delay, phaser, tremolo, acoustic boost etc. from the body of the guitar using our patent pending vibration control system.
Bluetooth Speaker
The guitar body can amplify audio from third party sources such as YouTube, Spotify, iTunes, and even Skype.
Record, Loop, and Share
Instantly record new song ideas & guitar licks and share them with your friends on the cloud. Use our looping feature to create your ownbacking tracks to jam over.
Mobile App Control
Use our mobile app to control the settings on the guitar, customize effects, share recordings, and manage backing tracks. Available on Android TM & iOS.
Responsive & Dynamic Acoustic Guitar
Built with custom specs that guarantee excellent craftmanship, natural feel, and a rich range of tones.
Extra Features
Tuner, metronome, volume control, EQ, real-time effect control, input and output jacks.
Artificial Intelligence
Our AI algoritms maximize the quality of your sound and add features that increase the boundaries of your creativity.
Here is just a taste of what the HyVibe Guitar can do.
Subscribe to our YouTube page to see more
Sign up for HyVibe updates
Email address
SUBSCRIBE!
Copyright © 2017 HyVibe. All Rights Reserved. Privacy Policy
Websites
facebook.com/hyvibe/ twitter.com/hyvibe_audio youtube.com/hyvibeaudio hyvibe.audio
hyvibe
Hi everyone!
Great to be in the forum.  We thought you might be interested in some more examples of videos with our guitar:
Effect sampler:
Distortion/sustain:
HyVibe Guitar as a Speaker(HyVibe Tracks)
Many many more on our YT page:
https://www.youtube.com/hyvibeaudio
Smash
Much more obvious FX sounds than the tonewood which only really seems to deliver a decent reverb. In comparison the delays on hyvibe sound much punchier, clearer and less muddy based on the videos. And the phaser and chorus fx great!
But then you're tied into a specific guitar which is the turn off for me.
Is after market fitment a possibility?
Smash
Ah....OK! You are proper intrepid with your explorations in guitar sound! :)
Those speakers are heavy man - but bloody loud granted
This looks interesting but not what you'd call pretty...
http://www.shamp.com.au/about.htm
hyvibe
Thanks! We get great sound quality primarily because we are exciting the top plate of the guitar.
Unfortunately at this time we are only offering our system embedded in a guitar, sorry!
Quote from: Smash on December 20, 2017, 01:16:12 PM
Smash
Without giving too much away is it a possibility or is there some irreversible "permanency" required in terms of exciter attachment?
hyvibe
With the right tools, anything can be removed :).
Like original Variax DSP board and electroncs
Both come in a nice guitar shaped box
The HyVibe system is available in a wide range of LAG guitars... built-in looping, fx, tuner, metronome, speaker, bluetooth..
for info: https://www.hyvibeguitar.com
Owners Manual
https://cdn.algam.net/pub/files/modes-d-emploi/lag/LAG-HyVibe-user-manuel-EN-V3.pdf
https://cdn.algam.net/pub/files/modes-d-emploi/lag/HyVibe-EN_JAN_2020_s.pdf
https://www.hyvibeguitar.com/downloads/
HyVibe MIDI Control for wireless Airturn footswitch (FX, Looper)
https://www.hyvibeguitar.com/airturn-midi-instructions/
HyVibe
Connect your guitar & unleash its full potential with the HyVibe Mobile App!
The HyVibe Mobile App gives you the power to create custom effects, EQ your sound, and program banks/presets on your guitar. All in real-time! You can also use it to update your guitar with new effects and feature updates that we are continuously releasing.
Since the app uses Bluetooth Low Energy, you must activate Location Services on your phone to use the HyVibe mobile app.
Now sold as a DIY Install version  $399
https://www.turnerguitar.com/shop/c/p/HyVibe-Smart-Acoustic-Guitar-System---ReplacementActuators-x59531290.htm
Billion Sound 12K05 Surface Transducer
http://www.billionsound.com/product/268.html?productCateId=15
Similar Replacement Transducer drivers
https://www.parts-express.com/Dayton-Audio-DAEX19CT-4-Coin-Type-19mm-Exciter-5W-4-Ohm-295-218?fbclid=IwAR0yW0J1UArTqzicUWYynQ3eJT-q9qMUgZuh8O71HURmkVpJCTjdCrvtCu0
Dayton Audio DAEX19CT-4 Coin Type 19mm Vented Exciter 5W 4 Ohm
Dayton Audio's 19 mm DAEX19CT-4 coin type exciter features the same ability to turn nearly any surface into a speaker, as other exciters and tactile transducers, only in a more compact package for working with smaller surfaces. This exciter's small size enables audio reproduction in places never imagined: toys, monitors, cabinet doors... even windows!
A neodymium magnet is employed to create maximum magnetic flux around the proprietary voice coil for increased sensitivity when compared to similar sized exciters. In turn, this reduces power requirements and makes it possible to use very small audio amplifiers, without sacrificing total output. Cooling holes placed strategically on this exciter's housing allows for higher power handling, for applications where more output is desired, while maintaining a small form factor.
To ensure maximum acoustic energy transfer between the transducer and the surface to which it is attached, 3M VHB (Very High Bond) adhesive is pre-applied... just peel and stick! Two PCB solder points keep installation and wiring as compact as possible.
Note: An exciter's frequency response and sensitivity are completely dependent on the exciter's designated surface. Thinner, smaller materials will tend to be louder and create a mid/tweeter response. Thicker, larger materials (with multiple exciters) will be slightly quieter but result in a more full-range sound.
Specifications: • Power handling: 5 watts RMS • VCdia: 19 mm • Nominal impedance: 4 ohms • Re: 3.8 ohms • Le: 0.04 mH • Fs: 637 Hz • Dimensions: 1.3" (33 mm) dia. x 0.51" (13 mm) H • Adhesive dimensions: 0.85" (21.5 mm) outside diameter, 0.63" (21.75 mm) inside diameter • Weight: 31.5 grams.
To learn more about Dayton Audio Exciters, and for help on which Exciter is right for you, check out Dayton Audio's Understanding and Using Dayton Audio Exciters Buyer's Guide.
Product Details
Brand   Dayton Audio
Model   DAEX19CT-4
Part Number   295-218
UPC   848791000966
Unit of Measure   Each
Weight   0.05
Product Specifications
Application   Full-Range Exciter
Power Handling (RMS)   5 Watts
Impedance   4Ω
https://www.parts-express.com/resources-buyers-guide-exciters
Quote from: hyvibe on December 21, 2017, 02:54:33 AM
That recently changed
HyVibe Now sold as a DIY Install version  $399
https://www.hyvibeguitar.com/shop/
And USA Hyvibe dealers on Reverb
Install instructions
https://www.hyvibeguitar.com/installation-documents/
Jezer
#11
Followers of Hyvibe might be interested in the video I made of installing the unit into one of my nylon strung guitars. I have included alternative methods making it much easier to connect the wires including a cutaway inspection hole in the back.
