AES67 / AES70 & Open Control Architecture
Started by Elantric, February 08, 2017, 01:08:03 PM
https://en.wikipedia.org/wiki/AES67
http://medianetworkingalliance.com/
The standard has been implemented by Axia,[15] Wheatstone,[16][17] Riedel,[18] Coveloz Technologies,[19] ALC NetworX,[20] Audinate,[21][22][23][24][25][26] Archwave,[27] Digigram,[28] Sonifex,[29]Yamaha,[30] QSC[31] and is supported by RAVENNA-enabled devices under its AES67 Operational Profile.[32]
http://www.archwave.net/aes67/
http://www.archwave.net/new-products-1-1/
https://static1.squarespace.com/static/57c6c266d2b8577131f53144/t/5880cc656a49633508bab243/1484835949559/Archwave_Brochure_A4+Bifold_v9.0_Draft_RPE_20160118.pdf
ARCHWAVE
Bahnstrasse 18b,
8603 Schwerzenbach,
Switzerland
Tel: +41 44 820 36 77
Email: sales@archwave.net
Thinking about implementing
AES67 audio networking?
If so, you should talk to us.
Archwave Technologies offers a range of AES67 and RAVENNA compliant modules that allow quick and cost-efficient audio-networking implementations into your products. Natively supporting AES67 & RAVENNA, as well as AES67 & SAP for direct connectivity to AES67-compliant DANTE systems, you can rest assured that Archwave's uNET modules offer you the best possible interconnectivity at the right prices.
Call us for further info or order your Evaluation-Kit and find out for yourself!
http://www.archwave.net/home
AES70 Open Control Architecture)
http://ocaalliance.com/
https://en.wikipedia.org/wiki/Open_Control_Architecture
OCA is an architecture for system control and connection management of media networks.  Now standardized as Audio Engineering Society AES70, OCA is capable of working effectively with all kinds of devices from multiple manufacturers, to provide fully interoperable multivendor networks.
OCA does not provide media transport, but can be used in conjunction with any available transport protocol (Dante, AVB, AES67, Cobranet,etc.). OCA protocols operate over standard Ethernet or 802.11 Wi-Fi networks.
OCA is a control protocol standard only, and does not define the programming design or user interfaces of devices or controllers.
OCA is modular, and may be used successfully in all sizes of devices, from small wall controllers to large audio processors and mixers.  It can be deployed in subsets.  For example, some products may use only OCA's connection management features, others may use only its audio processing features, while still others may use the entire feature set.
OCA is an open, license-free standard available to anyone – the full AES70 specification is available through the AES standards website
Although the OCA Alliance welcomes new members at any time, Alliance membership is not required to use AES70."
http://ocaalliance.com/wp-content/uploads/2016/02/2016.02.08-ISE-Booth-Show-v03-.pdf
http://ocaalliance.com/documents/AES%2044%20-%20OCA%20Technical%20Overview%20v02%20.pdf
