GP-10 Boston more than a feeling
Started by Jimmyward, February 03, 2017, 09:51:10 AM
Jimmyward
I'm trying to make a patch for more than a feeling. But having trouble with setup of the harmonizer. I've never had one and the options may as well be in a Greek.  :'(
GuitarBuilder
Try using the 12-string guitar model with chorus only (for the intro part).  Set the pre-delay to give you the amount of "doubling" you like.
For the overdriven guitar (and solos), you need the LP electric guitar model with rear pickup selected.  Tom's sound chain is as follows:
Guitar > Pre-EQ > Compressor > Distortion > EQ > Chorus > Echo
The critical EQ frequency is 500Hz, you need a dramatic cut there.  You can use the same chorus setting as for the acoustic.  The echo is tricky - a Rockman echo has dual delays.  His typical settings are 100ms and 150ms.
I'd start with MS 1959 I+II, but keep the treble settings low.  Tom uses minimal distortion; the compressor and EQ do all the hard work.  Keep the amp clean.  Experiment with the OD/DS FX instead.  The best chorus setting is Stereo2 with low rate and depth; keep it subtle.  Use DUAL-P delay and start with the settings mentioned above; it should be a fairly short echo with minimal feedback.  Tom does not use reverb.
Good luck!
Remember the actual original Boston guitar sound was a Marshall driven with a MXR 6 band equalizer (in some cases 10 band) .
This guy created a video explaining it (includes actual photo of Scholz's EQ unit setting):
Another video:
Take info from both videos to craft your sound!
Here's a french website http://rockman.fr/ where a guy has lots of info regarding the scholz rockmodules (I used to own a couple myself!)
jcifuentes
