Boss GP-10 USB AUDIO/midi
Started by SLICK, March 12, 2014, 04:37:40 AM
Terry50
#75
can you record raw guitar in mono and reamp it ?    ;)
If there isn't a button to capture raw,  we can turn all the effects and modeling off before recording.   8)
Alex Hutchings and Jay from Boss look at using the Boss GP-10 as an audio and MIDI recording device. The GP-10 has the ability to re-amp, re-guitar, play soft synths and score your music demonstrated by building up a track in Logic
MichiganMike
Very relevant posts here. I've been trying unsuccessfully to get the GP-10 to talk to the TCH VoiceLive 3 Extreme and it wont. Until I read this thread, I had some frustrating hours last week.
Godin xtSA, 1978 Fender Telecaster, Martin XC1T, Gibson Dobro, Trailwood Acoustic Bass
TC-Helicon VoiceLive 3 Extreme, Antares ATG-1, Boss GP-10, BeatBuddy,  Focusrite, MOTU, FL-Studio Producer (all licenses)
abhijitnath
What are latency times like on a Mac?
This is my proposed workflow:
13-pin into GP10 into computer for synth sounds back into GP10 outputs into Axe FX return. How long between me striking a note and it coming out of the Axe? Noticeable?
SEE LAST PAGE
http://cdn.roland.com/assets/media/pdf/BTS_GP-10_e03_W.pdf
Making detailed device settings
You can make detailed settings such as the input/output destinations for MIDI data and audio signals.
1. After performing steps 1–3 of "Selecting the Device Controlled by TONE STUDIO" (p. 15),
click the [DETAIL] button.
The "CONNECTION" screen appears.
2. Make desired settings for GP-10 MIDI input/output and GP-10 audio signal input/output.
IMPORTANT
Select the same type for MIDI IN and MIDI OUT. Connection is not
possible if you select different settings.
(Boss Tone Studio's I/O SETTINGS
BTS USB AUDIO IN Receive
IN (GP-10) = GP-10 Stereo Output
GK 1-2 (GP-10) = Direct (dry) feed from String 1(high E)  & 2(B)
GK 3-4 (GP-10) = Direct (dry) feed from String 3(G)  & 4(D)
GK 5-6 (GP-10) = Direct (dry) feed from String 5(A)  & 6(low E)
BTS USB AUDIO OUT Send
OUT (GP-10) = Send Stereo Computer Sound to GP-10 Stereo output
GK 1-2 (GP-10) = Feed Computer sounds to GP-10's String 1(high E)  & 2(B) GK Input ("Re-Guitar")
GK 3-4 (GP-10) = Feed Computer sounds to GP-10's String 3(G)  & 4(D) GK Input ("Re-Guitar")
GK 5-6 (GP-10) = Feed Computer sounds to GP-10's String 5(A)  & 6(low E) GK Input ("Re-Guitar")
search "RE-GUITAR" and "RE-AMP"
https://static.roland.com/assets/media/pdf/GP-10_e02_W.pdf
https://static.roland.com/assets/media/pdf/GP-10_Parameter_Guide_e02_W.pdf
