TWA Pedals - SS-01 SIDE STEP
Started by admin, February 08, 2018, 02:22:19 PM
http://www.godlyke.com/namm-winter-2018
As the NAMM show has blown past us, we just wanted to  update you on the
FOUR NEW TWA pedals
we debuted at the Stompbox Exhibit.
GD-02 GREAT DIVIDE
Yes, not necessarily a NEW pedal, but the 5th run is quickly selling out (less than 10 units left!). We will not be doing another run of Great Divides until after the four new pedals below are in production.
So get yours now before they're all gone.
SS-01 SIDE STEP
The Side Step is a variable-state, tap-tempo LFO that can be used to control any pedal with an EXP input. Just plug it in and tap to create unique new sounds and effects. EXP thru jack allows connection of your fave expression pedal at the same time.  SS-01 can also be hard bypassed to use the slave pedal in standard operating mode.
MM-01 MINI MORPH
The larval offspring of the Dynamorph, the MM-01 features an envelope-dependent drive circuit where the amount and type of saturation is intricately & inextricably linked to the input signal level. Multi-layered, highly complex waveforms meet & morph to create sizzling, splatter-full effects bordering on the bizarre
KM-01 KRYTICAL MASS
A reimagining of the legendary Maestro Bass Brassmaster,   Krytical Mass offers all the balls, grit, & girth of the original, but with more balls, grit, & girth. Ludicrous output & gain coupled with advanced EQ options create a nuclear core of unbridled sonic mayhem that teeters on the edge of total meltdown.  Radiation suit sold separately.
WX-01 WAHXIDIZER
Corrode your tone with the Wahxidizer. An Octave-Fuzz circuit based on the Univox classic, the WX-01 also features a parametric EQ that can be adjusted manually or via envelope-control to create a vast substrate of expressive, explosive & corrosive tones.  Toxic on guitar, massive on Bass, the Wahxidizer will melt faces & take you places.
