Boss GT100 anomalies
Started by musodata, January 27, 2018, 07:04:12 PM
musodata
GDay
1)Ok got the Reverb Decay to operate with the ExpPedal instead of the volume sweep. Brilliant.
But now when the WAH is switched on, the ReverbDecay still operates with movement of the footswitch.
When the ExpPedSW is activated to the WAH, the reverb should go off, but doesn't.
I've pretty much exhausted the visible options in the ASSIGN territories.
Any ideas?
2) Additionally, on the fly in performance there doesn't seem to be a way that effects etc can be tweeked on the fly without some serious gettingdownhavingalookmuckingabout
Which frankly I find incredible.
"ohyea, too much Drive on the (AmpEmulator) for this room, I'll just.. touch this, go there, scroll, fk I missed it, go back, "
etcetc
Have I missed a whole section on how to use this unit?
regards
Adrian K
You need to use one of the 8 Assigns to switch the Reverb "off" when the EXP Switch is engaged.
The secret is to set the Min and MAx parameters, so Min = Reverb Sw On, Max - Reverb Sw Off.
Since the EXP Switch toggles on/off, set the Assign to "Moment".
Once you learn the GT-100 menu system, it is very easy to tweak on the fly.
