is there enough juice on +7 line to power EMG pickups
Started by philjynx, December 21, 2017, 02:28:31 PM
philjynx
Quote from: philjynx on December 21, 2017, 02:28:31 PM
The EMGs will work down to 4.5 volts (so I've read....)
If you have ears - you would want to avoid that
Quote from:  philjynx on December 21, 2017, 02:39:36 PM
I'm fairly certain I have a couple of those, 4.5 was the absolute minimum. 7v would be like a partly discharged PP3? Not yet ready for the bin. Question is, is there enough spare current available?
There is probably enough for EMG only - not a Sustainer.
Roockies often do not understand the need to decouple the DC supplies between the GK system and the EMG system / or they mis-wire create a ground loop  = noise that need to be debugged
