Using GR-55 - Totally new to MIDI
Started by cmguitar, November 14, 2017, 08:36:16 PM
cmguitar
I'm totally new to using MIDI, and the reason I bought a used GR-55 is to use realistic effects  I can't get from regular pedals.  I am a utility player in a band and need to easily switch sounds while playing. The ones I really need for now are acoustic piano, B3, dobro, banjo, and various guitars.
I would like to be able to just hit separate buttons for each sound, rather than scroll through patches.
What's the best way to do this ? Use something like FC-300, or FC-200, etc?
Thanks in advance.
Yes, a midi foot controller will do the job,
one trap with the GR-55 and patch change to consider, is that the GR-55 produces a half second audio dropout on patch change.
cmguitar
Is there any advantage to using a Roland brand?
And when using this does one still have to get access to the GR-55, or  can it be in the backline, with just the controller in front on stage?
Thanks!
Quote from: cmguitar on November 15, 2017, 07:06:46 AM
Thanks!
The GK 13 pin cable length will dictate where the GR-55 resides - Longer GK Cables are prone to failures from mishandling / not wrapping correctly
GK 13 cable FAQ
https://www.vguitarforums.com/smf/index.php?topic=19481.0
Use the MIDI controller that suits your entire Rig control needs
MIDI Foot Controller Comparison
https://www.vguitarforums.com/smf/index.php?topic=12355.0
MIDI Tutorial
Learn MIDI Controller Setup / debug
You will need the GR-55 near you to access the Tuner, PCM Tone 'Hold', *.WAV file player, as these features are not midi accessible.
What's the cc number for the GR55 control pedal
Ok now I get it so live I can't easily send midi to turn on/off the control pedal. So my hard wired version is a better way to go for me. Well it does work pushing it on the GR55
cmguitar
Can't one use the switch or volume knob on the MIDI pickup,  and use a TS terminated cable from the 1/4 jack for normal pickups, or are you using only MIDI?
Again I'm a newb to the MID stuff :)
Quote from: whippinpost91850 on November 15, 2017, 06:37:42 PM
The concept is not to control the physical pedal through midi, but control the functions the pedal operates.
So if the CTL pedal operates "delay" on/off, you can control the 'Delay' on/off through cc# using an 'Assign', or directly control the delay using 'system exclusive (sysx) midi.
Quote from: cmguitar on November 15, 2017, 06:56:44 PM
I must point out one misconception, the GK pickup is not midi, it is a hexaphonic analog pickup (one pickup per string), with two buttons and a knob.
https://www.vguitarforums.com/smf/index.php?topic=14088.0
The buttons (S1/S2) and GK Volume knob are assignable to do controlling functions, and they can also send midi cc# commands out from the GR-55.
The Roland box (GR-55) receives the hex pickup signal, and from there , processes the audio, and/or converts it to midi as 'guitar to midi' output from the midi port or USB port.
