Controlling The Dry Mix In The 500-series Using An Expression Pedal?
Started by DarthTangYang, February 23, 2023, 07:24:38 AM
DarthTangYang
Hello!
I'm building a W/D/W rig and the Boss 500-series will make up the wet section of my setup. The question is, can I use an expression pedal to control the amount of dry in the mix through the MIDI ports? So basically a smooth transition from kill-dry to a full wet/dry mix with a pedal? Or would I need to get a dedicated Line Mixer with an expression pedal input for this?
The Boss 500's will all sit in loops of a programmable Effect Loop Switcher, something like a Boss ES-8 which has MIDI ports and an Expression Pedal port. Theoretically this feels like it's do-able but better to ask those here who might have more experience with this stuff.
STEREO WET
2 Hughes & Kettner Vortex Black Series heads/ H&K 4X12 cabs Celestion Rockdriver Jr's.
MONO DRY
Orange TH30/Harley Benton 2X12 cab Celestion V30's.
Victory V4 The Kraken
PEDALS
Dunlop CryBaby
Electro Harmonix - Green Russian Big Muff
TC Electronic - Vortex
Boss DD-500
Boss RV-500
Boisdelac
Read the user manuals of your 500 series effect pedals... see section "assign"...
You can assign a MIDI CC# to a certain parameter or function (volume wet/dry, effect type, effect rate, effect on/off) within your effect pedal.
If your MIDI-controller can provide MIDI CC# you can control the effect pedal.
