Problem with Roland GR33 mono mode, connecting to Roland D-05 via midi cable.
Started by derf, February 01, 2023, 04:03:17 AM
derf
When playing the D-05 in mono mode  only 1 string (high E string) sounds via midi cable and set to mono mode.
All midi settings are correct, both on the Gr33 and on the D-05.
After a lot of searching (google, manuals, etc.) it now works but via a detour.
I think cc126 (mono mode) is not sent from the Gr33. I tested this with both sysex via the laptop with midi interface and with the Behringer BCF2000. Both ways work.
So I programmed a push encoder with cc126 on the Behringer. One push of the button and mono mode then works on all 6 strings without any problem.
My question is now : Is there a possibility that the cc126 command can only be sent from the Gr33 ? This would save the frustration of having to set up the Behringer every time. I also suspect that the midi delay would be minimal without extra midi cable(s).
gumtownadmin
I don't think the GR-33 can do that,
the other solution would be to have the D-05 in mono mode all the time without needing cc#126 maybe if possible ?
