Noise Machine Straight Vibin' Edition
Started by Elantric, February 20, 2024, 11:24:42 AM
https://thisisnoiseinc.com/pages/noise-machine-nmsve
NMSVE
The main idea behind NMSVE was to create a portable MIDI controller made for the modern musician. A device that's compact, functional, and can be used for all kinds of MIDI purposes WITHOUT taking up valuable desk space.
How does it work?
NMSVE works by wirelessly connecting to MIDI capable software on your mobile device, iPad, or Mac/PC via Bluetooth.
Once connected, each of NMSVEs 12 buttons send unique MIDI notes while the slider cycles between 7 banks for these buttons - giving you a total of 84 unique MIDI notes across the board. Meanwhile, the knob can be mapped in software to control effects!
For a full rundown of Noise Machine (NMSVE) click here.
What can I use it for?
With software you can integrate NMSVE into your existing setup or use on its own to create amazing beats, control FX, trigger samples, play synths, drum, lighting, and just about anything else you can imagine - all in the palm of your hand 🤲 ✨
Features
12 buttons
7 bank slider
MIDI effects knob
Choice of 12 different channels on start-up
Connects via Low Latency Bluetooth MIDI
Compatible with iOS, iPadOS, Mac, Android, Windows 10, and direct to hardware through CME WIDI adapters
USB-C charging port with indicator
Massive battery life (9-12 hours per charge)
Open sourced
Exposed pinouts
What You Get
1x NMSVE
1x USB Type C Cable
2x Stickers
