GT-100 is there a way to disable the volume foot volume ?
Started by mantra, May 08, 2022, 11:04:03 PM
mantra
Hi
maybe with the assign feature
because i want to use the expression pedal to change increase and decrease an effect parameter , in my case the delay feedback
but working on a patch , i can increase and decrease the delay feedback , and the expression pedal lower and increase the volume too
thanks
Boisdelac
Try to switch off EXP1 in the Control Functions. Have a look at the encloses screen capture from tone studio.
Than set a momentary assign for EXP1 relating to Master Delay Time.
Also have a look @ the parameter guide page 30
https://static.roland.com/assets/media/pdf/GT-1000_parameter_eng11_W.pdf^
But I would recommend to use an external expression pedal connected via exp2 or exp3 to leave the internal expression pedal to control the volume, the tuner and the wahwah.
mantra
Quote from: Boisdelac
I wanted for gt-100 , i did a mistake and i wrote in this sub forum
I guess it could be done , i mean disable the foot volume and enable the expression pedal to increase/decrease an efffect values
mantra
Quote from: admin on May 09, 2022, 07:15:35 AM
Easier using external expression  pedal
hi
but it does increase/decrease the effect value + the unit volume
it's a mess
i would like to disable the volume pedal , and enable to increase/decreae the effect only
can i do it?
how?
thanks
mantra
Quote from: admin on May 09, 2022, 10:19:06 AM
hi
but i can't find a way to disable the volume pedal with the assign
if you find out , i would like it
From memory,
if using GT-100FxFloorBoard editor, go into the SYSTEM settings, and select the INTERNAL PEDALS page.
Then set the EXP PEDAL control to SYSTEM (all patches will be the same)
Then set the function to OFF.
done !!  8)
mantra
Quote from: gumtown on May 09, 2022, 01:09:04 PM
From memory,
done !!  8)
Hi
but i want to disable the volume pedal for 1 patch and use the expression pedal to increase/decrease effect value
the problem is that the expression pedal in my patch increase/decrease volume and effect value
and i'm a GT-100FxFloorBoard  's addicted ;)
thanks
If you only want the EXP Volume disabled for a patch,
go into the "PEDAL/FX"
select the "EXP FUNCTION" to "OFF"
before disabling the EXP foot volume function, set the foot volume to a level you want first.
mantra
Quote from: gumtown on May 09, 2022, 11:33:18 PM
Hi Gumtown
yes , it works
thanks
