Using a Tube head thru MKll 100w
Started by Plekmyneck, April 29, 2022, 07:27:59 AM
Plekmyneck
I have an amp head I have been running into the 8ohm Amp in line. When you do that is basically only uses the power of the Katana, and all other Katana functions and effects are bypassed. Is there a way to safely connect an amp head and still have use of the Katana effects, without any of the Katana amp sounds, Brown, Lead, crunch?
