As mooncaine prescribed
Started by pasha811, April 17, 2022, 12:06:29 AM
pasha811
...long ago...a famous statement: sounded like guitars are made to be played not to be placed behind a glass in a museum...so I decided to make two tiny holes with my Dremel and attached the GK2A to my 1989 Strat Plus. I have removed the double tape that was getting less stronger after 11 years so after i installed it with screws I have removed the .20 mm tape thickness and the air gaps that were forming so I could lower the action a little. Not ideal but if in the future I  need that I will carve the pickguard, while retaining the holes in the wood. I had to reduce the GK2A sensitivity after It lowered the strings. So Moon was right. Guitars are made to be played.
