Roland Fantom 06 / 07/ 08 keyboards
Started by admin, March 15, 2022, 05:16:30 PM
https://www.roland.com/us/promos/fantom-0_series/
Standard Features
FANTOM-0 Series
SERIES OVERVIEW VIDEO
Explore the FANTOM-0 series
Workflow
Your musical everything.
FANTOM-0 has everything you need to create and perform at the highest level. And with its interactive design and expansive I/O, it blends into every workflow with ease.
FANTOM-0 Series
FANTOM-0 Series
Extraordinary sounds.
FANTOM-0 includes thousands of professional sounds from Roland's immense, trendsetting library, with further expansion available through Roland Cloud. Create with synthesizers and rhythm sounds that have defined entire musical genres. Build organic compositions with pianos and other acoustic instruments. Or shape sounds of the future with FANTOM-0's deep array of modern synthesis tools.
FANTOM-0 Series
Inspiring playability.
Every FANTOM-0 model feels fantastic under your fingers with responsive custom keyboards and loads of high-res controls. Choose from the 61-note FANTOM-06 or 76-note FANTOM-07 and their synth-action keyboards. Or go for a weighted-action experience with the FANTOM-08 and its 88 ultra-responsive keys.
FANTOM-0 Series
FANTOM-0 Series
Build songs in a flash.
Designed for non-stop music creation, FANTOM-0 lets you shape sounds and make music without interrupting the flow. With the hands-on knobs and sliders, color touchscreen, quick sampling features, and clip-based sequencer, every session with FANTOM-0 is inspiring, productive, and fun.
FANTOM-0 Series
Your creative hub.
FANTOM-0 slides seamlessly into modern production setups with a built-in 4x32 USB audio interface, while native integration with Logic Pro, MainStage, and Ableton Live lets you interact with the software using the touchscreen and hardware controls. Going further, you can freely combine soft synths with FANTOM-0's onboard sounds and interface with your favorite MIDI hardware via the dedicated MIDI output.
FANTOM-0 Series
Make music everywhere.
FANTOM-0 instruments are easy to carry from your home studio setup to rehearsal rooms and performance stages. They weigh significantly less than most other professional keyboards, thanks to molded body designs that are sleek, attractive, and ultra-rugged.
Sounds
Play and produce with Roland's best.
Equipped with Roland's most innovative technologies, FANTOM-0 puts a huge selection of electronic and acoustic sounds at your command. And with a growing range of expansion options from Roland Cloud, you'll never run out of creative fuel.
FANTOM-0 Series
FANTOM-0 Series
Next-generation synthesis.
Explore the influential sounds of Roland's storied past and craft the sounds of tomorrow with the ZEN-Core Synthesis System, our most advanced synth engine to date.
ZEN-Core
FANTOM-0 Series
A grand experience.
FANTOM-0's all-new SuperNATURAL pianos play and respond just like their acoustic counterparts, and you have a range of onboard tools to customize them for your style and touch.
FANTOM-0 Series
SuperNATURAL power.
With Roland's SuperNATURAL technology, you can play nearly any acoustic instrument imaginable with unparalleled sound quality and authentic articulations and response.
FANTOM-0 Series
Organic organ.
Evolved from our famous VK organ series, the Virtual ToneWheel engine faithfully emulates the sound-generating process of a real tone wheel organ, backed by quick-fire playability and direct control with the touchscreen, sliders, and knobs.
Deep sampling.
Using FANTOM-0's intuitive sampling tools, you can easily expand and personalize your musical palette by capturing internal sounds, hardware devices, DAW tracks, and more.
Capture directly to the pads for triggering.
Capture to the keyboard for instant pitched sounds.
Build detailed multisamples to create new ZEN-Core tones.
FANTOM-0 Series
Expand your vision.
With Roland Cloud, you can dive even deeper into the historic and ever-evolving world of Roland synthesizers. Model Expansions let you infuse FANTOM-0 with the authentic sounds and unique characteristics of the JUPITER-8, JUNO-106, and other vintage icons. And with the growing selection of Wave Expansions, Sound Packs, Sample Packs, and more, you'll always keep your music sounding fresh.
To get started, you can download 15 Wave Expansions and 10 Sound Packs at no charge from Roland Cloud when you purchase a FANTOM-0 keyboard.
Interface and Control
No roadblocks. Just pure creation.
FANTOM-0 supports your music every step of the way with a smooth, rapid workflow that's completely free of confusing modes and technical frustration. Immensely powerful yet easy to use, FANTOM-0 enables continuous creation with fluid composition tools, instantly recallable setups, deep computer integration, and more.
FANTOM-0 Series
FANTOM-0 Series
Make a scene.
With custom creative spaces called Scenes, you can store sounds, patterns, performance layouts, templates, and more and recall them with a single touch. A Scene can also be an entire song or section of a song, and they can be chained together and switched seamlessly with no gaps or glitches.
FANTOM-0 Series
Sound that moves.
FANTOM-0 makes it easy to create long evolving passages, modular-style animated textures, and sounds with deeply intricate movement. You have two LFOs per partial and four partials per tone—and since you can stack 16 tones, that's a staggering 128 LFOs per voice! Step LFOs are also available with 16 steps of beat-synced automation and 35 curve choices per step.
FANTOM-0 Series
FANTOM-0 Series
From spark to fire.
Different musical genres need diverse production styles and specialized tools. You can capture music in a variety of ways with FANTOM-0, from real-time and step sequencing to the famous TR-REC pattern sequencer inspired by iconic Roland drum machines like the TR-808 and TR-909.
FANTOM-0 Series
Get vocal.
Connect a mic to the rear-panel input and sing in the studio or on stage with high-quality processing from FANTOM-0's wide-ranging effects. Or fire up the 32-band stereo vocoder and use the expressive power of your voice to create classic VP-style ensemble tones, robot voices, otherworldly textures, and more.
FANTOM-0 Series
Instant control.
FANTOM-0 lets you realize musical ideas as quickly as they come. The color touchscreen provides instant interactive control, and the hi-res knobs deliver organic, ultra-detailed response. There's also a dedicated synthesizer section with oscillator, filter, and envelope controls, plus buttons and pads for sequencing, triggering, and more.
FANTOM-0 Series
Maximum expression.
Some players like levers or wheels, while others prefer external pedals. With FANTOM-0, you can use any of them—or all of them. And there's even a dedicated USB device port to extend your workflow with your favorite USB MIDI controller.
FANTOM-0 Series Lineup
Find the FANTOM-0 synthesizer for you.
FANTOM-0 brings your creative world together, combining the sonic power and fluid workflow of the top-of-the-line FANTOM series in streamlined instruments that go everywhere your inspiration takes you.
FANTOM-0 Series
FANTOM-08
Streamlined 88-note weighted-action synthesizer with sounds and features inherited from the flagship FANTOM series.
Tone   ZEN-Core
SuperNATURAL Acoustic
SuperNATURAL Acoustic Piano (EXSN01/03 Preload)
SuperNATURAL Electric Piano (EXSN02 Preload)
VTW Organ (Only ZONE2)
Various MODEL sound generators (Require adding EXM Series)
Size   1,393(W) x 354(D) x 138(H) mm
54-7/8(W) x 13-15/16(D) x 5-7/16(H) inches
Weight   14.8kg
32 lbs 11 oz
Keyboard   88 keys (PHA-4 Standard Keyboard: with Escapement and Ivory Feel)
Stand (sold separately)   KS-G8B, KS-10Z, KS-12, KS-20XView Product
FANTOM-0 Series
FANTOM-07
Streamlined 76-note synthesizer with sounds and features inherited from the flagship FANTOM series.
Tone   ZEN-Core
Size   1,218(W) x 323(D) x 95(H) mm
48(W) x 12-3/4(D) x 3-3/4(H) inches
Weight   7.0kg
15 lbs 7 oz
Keyboard   76 keys (with velocity)
Stand (sold separately)   KS-10Z, KS-12, KS-20XView Product
FANTOM-0 Series
FANTOM-06
Streamlined 61-note synthesizer with sounds and features inherited from the flagship FANTOM series.
Tone   ZEN-Core
Size   1,006(W) x 323(D) x 95(H) mm
39-5/8(W) x 12-3/4(D) x 3-3/4(H) inches
Weight (no stand)   6.0kg
13 lbs 4 oz
Keyboard   61 keys (with velocity)
Standard Features
Sounds and features inherited from the flagship FANTOM series
Seamless workflow with no confusing modes
Light and durable molded body designs for easy transport
Play and produce with thousands of electronic and acoustic sounds powered by Roland's advanced ZEN-Core and SuperNATURAL technologies
New SuperNATURAL pianos with authentic acoustic grand sound and response
Virtual ToneWheel Organ with harmonic bar control and quick-fire playability
Deep onboard sampling features
Scenes contain settings for all 16 layers plus effects and patterns
Clip-based sequencing with instant pattern recording and triggering
TR-REC sequencer inspired by classic Roland drum machines
Color touchscreen, high-resolution knobs, sliders, RGB performance pads, and dedicated synth control section
Pitch/mod lever and illuminated pitch and mod wheels
Massive DSP power for plenty of polyphony and smooth sound transitions
4x32 USB audio interface and native integration with Logic Pro, MainStage, and Ableton Live
Mic input and powerful onboard vocoder
Support for Model Expansions, Sound Packs, Sample Packs, and more from Roland Cloud
Comes with 15 Wave Expansions and 10 Sound Packs, available for download from Roland Cloud
Compatible with FANTOM Scenes that use ZEN-Core, SuperNATURAL, and Virtual ToneWheel Organ sounds
