Valeton - GP-100 MFX/CAB IR/ Looper / USB Audio Interface FAQ
Started by admin, June 02, 2020, 04:09:42 PM
Valeton GP-100 Owners Manual
https://v2sources.siiite.com//enclosure/sources/WMBxBvylTvYKWuZW/GP-100_Online%C2%A0Manual_EN_V01_200604.pdf
GP-100 Firmware Update Guide
https://v2sources.siiite.com//enclosure/sources/ljLpeebQJolNecqP/GP-100_Firmware%20Update%20Guide_EN_V01_200730.pdf
Valeton GP-100  MFX/CAB IR/ Looper / USB Audio Interface ($150 USD)
https://www.valeton.net/GP_100.html
Portable sized All Metal casing for taking anywhere
Dimensions: 198mm(W) x 134mm(D) x 28mm(H)
Unit Weight: 800g
Inside the GP-100 we loaded our powerful HD digital modeling system, delivering you organic living tone and over 140 effect selections including 45 legendary guitar/bass/acoustic amp simulations, 40 highquality factory cab IRs, and more. We also offer you 198 presets (99user + 99 factory) fine tuned by skilled professional musicians for playing any music genre you like.
3rd party IR support - recreate your favorite cab tones
GP-100 offers you 20 user IR storage slots. Customize your own tone now!
Like jamming with a real band
Use the built-in looper, drum machine and aux input to play with your own tracks. The looper features max. 90 seconds looping time, and the drum machine gives you 100 different patterns (incl. metronomes).
Record and share your ideas
You can turn your GP-100 into an USB audio interface by simply connecting your unit to a computer/mobile phone (for mobile devices, a USB OTG cable is needed). Then you can record, mix and share your songs whenever you want. We also offer you a free ASIO driver for Windows users.
FEATURES
● 24-bit 44.1kHz signal processing
● Advanced digital modeling technology delivers organic tone
● Over 140 high quality effects
● Editable effect chain
● 45 legendary guitar/bass/acoustic amp types
● 40 factory IR cabinets
● Supports storing 20 user IRs
● 50+ dynamic/drive/EQ/mod/delay/reverb effects
● USB audio interface function with stereo audio streaming
● Stompbox and preset modes for different situations
● 198 presets (99 factory, 99 user)
● High quality looper
● 100 high quality drum patterns
● Durable metal chassis and footswitches
● Built-in chromatic tuner
● Intuitive PC/Mac editor
● 1/4" stereo outputs
● 1/8" headphone output
● Stereo 1/8" Aux Input
● Built-in expression pedal
● DC 9V power supply
SPECIFICATIONS
A/D/A Converter: 24-bit high performance audio
Sampling Frequency: 44.1 kHz
SNR: 110dB
Maximum Simultaneous Effects: 9
Preset Memory: 99 User Presets/99 Factory Presets
Looper: 90 seconds of record time
Drum Machine: 99 Patterns
Analog Input Connections
Guitar Input: 1/4" Unbalanced (TS)
Input Impedance: 1M Ohms
Aux Input: 1/8" Stereo (TRS)
Aux Input Impedance: 10k Ohms
Analog Output Connections
Left/Right Outputs: 1/4" Unbalanced (TS)
Left/Right Output Impedance: 1k Ohms
Headphone Output: 1/8" Stereo (TRS)
Headphone Output Impedance: 47 Ohms
Digital Connections
USB Port: USB 2.0 Type-B
USB Recording Specification
Sample Rate: 44.1 kHz
Bit Depth: Supports 16-bit or 24-bit
Dimensions: 198mm(L) x 134mm(W) x 28mm(H)
Unit Weight: 800g
Power
Power Requirements: DC 9V, 500mA
Quote from: CBHTele, post: 30638544, member: 64515Seems to be a lot for the money.
I have seen Valeton products on Amazon; do we know if they are independent, or part of another company (read: they're not Mooer, are they?)?
Valeton is owned by Hotone
Majiken
Demos sound okay, missing I/Os that would make it interesting for me, but an outstanding price point!  Methinks this will take some of the budget cake.....
www.majiken.rocks
https://www.facebook.com/groups/ValetonUsers/
Valeton GP-100 is a "mini Ampero" all metal, smaller - and (big deal) has dedicated headphone output and I can Place any effect anywhere - and has a StompBox Mode and can enable 4 FX per Expression pedal Sweep
(like a Boss GT-100)
I need Reverb 1st in signal chain for vintage Surf!
COMPARE Valeton GP-100 & NUX MG-300
Valeton GP-100 EDITOR
Valeton GP-100 v1.3 firmware Owners manual
https://v2sources.siiite.com//enclosure/sources/HZUMSCocgpvxmEmy/GP-100_Online%C2%A0Manual_EN_Firmware%20V1.3_200714.pdf
$145
https://www.earthcitysound.com/listing/valeton-gp-100-multi-effects-processor-looperdrum-machine140-effect-settings/34528484
I posted the NUX MG-300 vs Valeton GP-100 comparison spreadsheet to the MG-300 User Facebook group
https://www.facebook.com/groups/879966155822846/
( big mistake - their Admin already deleted it
( they considered "Way Off Topic", (?)
Oh well -
Further Valeton GP-100 discussions here
(Unboxing demo with Piccolo Bass)
Quote from: ChrisVereb, post: 30942480, member: 156151Is the chain of this thing "put the given blocks in any order" or "put any block in any order until you hit DSP max"?  For example: can you run multiple OD/DST blocks in the same patch or multiple delay blocks in the same patch?
The effects are fixed in that you can not change all 9 blocks to become nine Amp models
But you can easily move any block in any order  - RTM
or watch the Youtube demos
thus one is in spanish  - but describes all GP-100 features - enable CC translate for closed captions in english
mchad
Sounded alright for the money. Feature packed. It might be joined down the track by a bigger version? With midi.
Couldn't see sub divisions for time based effects. And trems and such.
New Valeton GP-100 FW 1.50
https://www.valeton.net/firmware.html
Valeton GP-100 FW 1.50 manual
https://v2sources.siiite.com//enclosure/sources/lbhxvKcWfbkczfTl/GP-100_Online%C2%A0Manual_EN_Firmware%20V1.5_200928.pdf
GP-100 Firmware Release Note
Changes & Bug Fixes in Version 1.5 (Released 9/30/2020)
1. Tap Tempo function added (hold left footswitch to engage)
2. Global tap tempo control for PRE, MOD and DLY modules added
3. Optimized IR cabs.
Changes & Bug Fixes in Version 1.4 (Released 9/1/2020)
1. You can now set more language options available (Simplified Chinese, Traditional Chinese, English, Japanese, Korean, Spanish, German, Italian)
Changes & Bug Fixes in Version 1.3 (Released 7/14/2020)
1. Some drum rhythms cannot be correctly loaded - FIXED
2. Now drum tempo will not be changed when you change drum rhythms
Version 1.2 (Released 6/5/2020)
Updated Editor 1.20 for FW 1.50
https://www.valeton.net/software.html
