VG-99 meets macOS Monterey (M1 & Intel)
Started by Vaultnaemsae, December 25, 2021, 11:11:53 PM
Vaultnaemsae
It lives!!! Useful info if you've jumped over to an M1 Mac or have an older Intel device running Monterey. For a fistful of spondoolies you can run the original editor in the 64-bit environment. It should also be compatible with Big Sur and Catalina. Seasons greeting to all Vguitar Forum members.
https://youtu.be/RxfsEJylqd0
Vaultnaemsae's SoundCloud:
pasha811
That's great man! The best news of 2021!  8)
Just one question :
Can VG99 working this way via USB in Standard Mode?
Thanks! Season Greetings!
Vaultnaemsae
Hey pasha11,
The same rules still apply regarding the use of a 5-pin MIDI to USB adaptor. The big deal is that there was no way to run a non-ARM VM on M1 devices and there are no ARM compatible drivers for most (if not all) MIDI interfaces so you couldn't access the editor on WIN 11 for ARM processors via any means. Now you can bypass the VM approach.
Standard mode still supports 16-bit, 44.1kHz audio only.
If you're on an Intel device you can run advanced mode (at least under certain conditions) but it only supports the audio part. You need the DIN-To-USB adaptor either way.
pasha811
Quote from: Vaultnaemsae on December 26, 2021, 01:47:46 AM
Hey pasha11,
Thanks now it's clear to me.
Again, the best findings of 2021! 8)
Headless68
Nice one Luke. not heard of this software before.
Also - nice T-Shirt :-)
....and using 'Spondoolies' - not heard that for years :-)
Vaultnaemsae
Quote from: Headless68 on December 27, 2021, 04:54:40 AM
How about didjiridollars and bullywonkas?
jfwiddifield
My Mac is using OS Ventura 13.2.1 with the M1 processor. In my applications, both the editor and library apps are grey and unresponsive. I have tried to log each into Crossover without any luck. I'm at a loss. Any help would be appreciated.
