3 New Guitars Completed
Started by Zummooz-fgn, September 28, 2011, 05:54:10 AM
Zummooz-fgn
Hi all.
Couple of guitars I have just completed building. ;D  Yep one has a GK-3 installed.  ;)
Few shots here of each one & will add some more pic's of each one (in this same 1st post) a bit later on ...
When I can stop playing them  ;D
If you look closely at the spec's all have a RAW Necks & all are smooth & fast to play on.
Anyone that has a RAW neck will know what I mean, these RAW necks are just outstanding to play.
If you haven't gathered by now, I'm very impressed at what Warmoth dose !!
Also try & do each build I do with different pickups.
All put together by me.  ;D
Number 1
Name ..... 'Bluesy'  :P
This one I tried to get a warmer feel to a Strat .... has some great sound to it.
... Body ...
Top Rout
Mahogany (Solid)
Contoured Heel
Quilt Maple Top
'Blue Burst' on Top
Black Gloss on Back.
Black Burst Edges
Natural Masked Binding
White Pearl Custom Cut Pickguard (by me)
... Neck ...
Raw Quartersawn Concalo Alves
Pau Ferro Fretboard
Standard Thin
10'' - 16'' Compound Radius
Nut Width 1 & 11/16''
Stainless Steal Frets SS6115
White Graph Tech Nut
Pearloid Nightsawn Inlays
Sperzel Lok Tuners
Custom Neck Plate
... Hardware ...
Seymour Duncan Humbucker Jazz  (Neck)
Seymour Duncan Humbucker JB  (Bridge)
6-Hole Vintage Tremolo
2 x 500K CTS Pots
1 x Orange Drop Capacitor
1 x Volume, 1 x Tone
3 Way Switch
Strat Knobs with Position Pointers
Standard Strap Buttons
Strings Fender Super Bullets .010 - .046
Sleeps in a Gator Hard Case  :D
Number 2
Name .... 'Wild Zebra'
This is one killer guitar ..... Totally over the moon with this one.  ;D
Sustains forever  :o  Just beautiful to play !!
When I received this body I just starred at it for ages & dribbled all over my keyboard  :P
This craps all over my recent Gibson SG '61 Reissue
... Body ...
Rear Rout
Alder (Solid)
Contoured Heel
Very High Grade Quilt Maple Top
Black Dye finish on Top
Black Gloss on the Back
Black Burst on Edges.
Recessed TOM - Angled Strings
... Neck ...
Vintage Modern, Raw Pau Ferro
Ebony Fretboard
1 11/16" Nut width
Graph Tech Black TUSQ Nut
10 -16" Compound Radius,
Standard Thin Neck
Mother Of Pearl Dot Inlay
Sperzel Lok Tuners
Custom Neck Plate
... Hardware ...
Tone Pros Bridge
Top & Bottom Ferrels
Bare Knuckles Humbucker  Mule (Neck)
Bare Knuckles Humbucker  Abraxas (Bridge)
3 Way Switch
2 x 500K CTS Pots
1 x Vol, 1 x Tone
Tele Heavy Knurled Knobs
Metal Mount Rings
Tremolo Cover Black / Red
Number 3
Name ... 'Redback'
This is my 2nd Warmoth Build, WITH a GK-3 Installed & WOW WOW WOW this is just perfect in every way  ;D
Only just finished this one the other day. Been testing on the VG & GR & is tracking perfectly .... simply amazed ....
... Body ...
Rear Rout
Alder (Solid)
Contoured Heel
Red Dye finish on Top
Transparent Red on the Back
... Neck ...
Warmoth Pro Raw Indian Rosewood
Indian Rosewood Fretboard
1 11/16" Nut width
'59 Roundback Neck
Mother of Pearl Dot Inlay
Custom Neck Plate
Sperzel Lok Tuners
... Hardware ...
Seymour Duncan P-Rails (Neck)
Seymour Duncan P-Rails Hot (Bridge)
3 Way Switch
2 x On / Off / On Mini Toggle Switch (for P-Rails)
2 x 500K CTS Pots
1 x Volume, 1 x Tone, 1 x GK-3 Vol
1 x GK-3 Mini Switch
Roland GK-3 Pickup (Kit) Internal Install
13pin Midi & Mono Input Jacks
Strat Reflective Knobs
Chrome Switch Tip
Metal Mount Rings
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
                                                         ******NOW I NEED A BIGGER CUPBOARD******
MCK-fgn
Wow wow wow! You are now officially the master integrator in Oz. I think this should be your new line of work if you care to change fields. You have a great eye for bling and fit. Congratulations!
PS. I see your trademark pickguard design in making yet another appearance. Great!
gumbo-fgn
Good One Zum!!!
..gonna hafta get my act together..... ;)
icing777-fgn
They all look GREAT!!!! I am jealous! :)
Play on, my friend !!!
photonutalan1-fgn
Superb and flawless work, Zummooz; they're beautiful!
cgarlie-fgn
Well, I would have gone for a SD Pearly Gates for the bridge of the Bluesy, but can't really argue with your choice -- well done :D
Charlie
Gibson Digital Les Paul (HD-6X)
PRS SC245 (57/08)
Gibson '83 Lucille
SRV Custom Strat
"Claptonized" 60th Anniversary Strat
PRS SAS
(Original) Dan Armstrong "See-through"
Variax JTV-69
Zummooz-fgn
Thanks all for your comments  ;D
Quote from:  cgarlie on September 30, 2011, 09:17:13 AM
Charlie
Yep got a Pearly Gates  ;D  in the neck of this one   https://www.vguitarforums.com/smf/index.php?topic=32939.0
I do like the SD's, got quite a few now in different combo's.
I really like this combo on another one I have  https://www.vguitarforums.com/smf/index.php?topic=32931.0
Thanks again all  :D
aliensporebomb-fgn
All quite gorgeous but the gray one with the lovely top reminds me a lot of my #1.  Lovely!
