need help with AX 100 and left-hand bass - not all notes are playable
Started by GoaSkin, May 11, 2021, 04:10:08 PM
GoaSkin
Hello,
I am using a left-hand bass guitar with an Roland GK3-B pickup which works well with the GR-55 and the SY-1000.
Recently, we bought an AXON AX100 MK2 on eBay.
If I configure there a bass guitar with normal tuning (EADG), I am only able on the A and D strings to play the full range of notes. On the G-string, f# appears as the highest playable note and everything above isn't recognized. On the E-string, anything below D is ignored. If I configure transpositions for these strings, all grips are interpreted but pitched as espected. On the A and D strings, the whole range is playable including the notes which are ignored if I play them on the outer strings.
Does anybody know the reason why the outer strings are only partiable interpreted by the device if I use the normal bass tuning and knows the trick how to solve this?
Thanks for answers.
As Axon does not support Left Hand instruments, nor GK Pickups Reverse Mounted-Need to perform the left handed GK PU rewire mod
https://www.vguitarforums.com/smf/index.php?topic=3365.0
Shingles
Quote from: admin on May 11, 2021, 04:56:07 PM
Might work if you reverse-mount it on a left handed instrument???
Nik
