GT-1000 Core Looper
Started by Chrls, May 02, 2021, 05:54:16 AM
Chrls
Hi,
does someone maybe know if it is possible to clear the last played overdub without deleting everything played so far on the GT-1000 Core?
From the manual and a YouTube video it looks like you can only clear everything, which would be a little bit annoying if you already played several layers and then you make a small mistake in the current layer, so you would need to start complete from scratch again...
Is it really like this in the GT-1000 Core or can you also delete only the latest overdub without touching the rest?
Quote from: Chrls on May 02, 2021, 05:54:16 AM
Hi,
Sadly no
the GT-1000 onboard looper is a bit of a let down, intentionally crippled IMHO, worst Looper on any $1000 MFX in 2021.
GT1000 Core is same Looper
(Headrush Pedal  Board / Gigboard have a superior Looper - finally with MIDI control after latest Firmware
See Looper "PEEL" function which is what you seek
https://cdn.inmusicbrands.com/HeadRush/gigboard/v2_1_2-0520/Gigboard-User-Guide-v2_1_2.pdf
Chrls
Thank you for your response!
