GK3 and GR33
Started by pasha811, January 03, 2021, 02:15:08 AM
pasha811
Found a GR33 used in my area.
Is the GR33 working with a GK3? By reading the manual only the GK2A is mentioned.
is the GR33 tracking good (as much as it can be on a well setup GK3 and Guitar)?
In this video the poster states that : Recorded:19.09.2010.i'm useing here the Pedal too.Notice:The GR33 has tracking-problems.I use here my old GR30 for GK input.The GR33 is conected via Midi with the GR30,and the GR30 is the Contoller.The GR30 can kill all the Pitch Bend Data-Messages.And so i use the GR33 as a slave of the GR30.
Thanks!
Cheers
Pasha
Shingles
Nik
martinmj
One other thing to note-the output from the GK-3 is lower than that of the GK-2a so the output from the GK-33 rather low with the former. My headphones do not give a decent volume even at full volume.
I prefer Yamaha G1D pu
The GK-2A is most compatible with every system
Many own and use all generations of GK processors with same guitar-but many predate the arrival of the lower signal output GK-3 (2004)
Contact me if you want your GK3 converted to higher GK2A output ( then use "GK2A" as your GK Type on all 13 pin processors
Can wax pot the GK3 hex PU too
https://www.vguitarforums.com/smf/index.php?topic=43.0
