BOSS GT-1000CORE - Firmware
Started by admin, October 15, 2020, 10:17:44 PM
https://www.boss.info/us/support/by_product/gt-1000core/updates_drivers/3b1cf0f2-5139-47bc-a03b-848d359229b2/
GT-1000CORE SYSTEM PROGRAM (VER.1.01)
WHEN USING GT-1000CORE Ver.1.01 IN COMBINATION WITH BOSS TONE STUDIO FOR GT-1000 AND THE GT-1000 DRIVER
Use the most up-to-date versions in combination, as described below.
Windows 10 users
GT-1000CORE System Program Ver.1.01
BOSS TONE STUDIO for GT-1000 Ver.3.1.3 for Windows or later
GT-1000 Driver Ver.1.1.0 for Windows 10
Windows 7 / Windows 8.1 users
macOS 10.15 users
BOSS TONE STUDIO for GT-1000 Ver.3.1.3 for macOS / OS X or later
GT-1000 Driver Ver.1.0.1 for macOS 10.15
macOS / OS X users
GT-1000 Driver Ver.1.0.0 for macOS / OS X
HOW TO KNOW THE VERSION
Before you start, check the system program version of your GT-1000CORE.
While holding down [ EXIT ] button, turn power ON.
Continue to hold down EXIT until the GT-1000CORE logo appears on the display.
After a short while, the version information appears on the display.
If this shows the latest version (Version 1.01 or later), there's no need to update your GT-1000CORE.
After verifying the displayed version, turn off the power.
UPDATE HISTORY
[ Ver.1.01 ] OCT 2020
Bug Fixes
Under certain conditions, VIBRATO fails to work as desired when switching patches.
Behavior is not as desired when the STEREO LINK parameter for SP.SIMULATOR is set to OFF.
The effect level sometimes rises when CARRYOVER is active.
Under particular conditions, the DUCK parameter for REVERB fails to operate as desired when patches are switched.
Other minor bugs.
WHAT YOU WILL NEED TO UPDATE YOUR GT-1000CORE
GT-1000CORE
USB cable
* The update is carried out with the unit and the computer connected via USB.
Provide a cable suitable for connection to the computer you're using.
Computer (Windows or Mac) equipped with a USB port compliant with USB 2.0
CAUTION WHEN PERFORMING THE UPDATE
If you update on the normal mode of GT-1000CORE against the correct procedrue, this update data may destroy the system program.
Never power-off your GT-1000CORE while the update is in progress!
If a power failure or similar accident occurs during the update process, the GT-1000CORE won't be able to start up in normal operating mode. This will require servicing, so you will need to contact Roland service center near you if this occurs.
We regret that we are unable to answer questions regarding the update procedure using this system program. Please perform the update responsibly, following the directions given in this document.
GETTING THE UPDATE FILE
Download the file named "gt1000core_sys_v101.zip".
Please open/extract the downloaded "gt1000core_sys_v101.zip" file on your computer to get the update file in the "gt1000core_sys_v101" folder.
PROCEDURE FOR THE UPDATE
Hold down [ WRITE ] button and turn on the power.
* Continue to hold down WRITE until "GT-1000CORE Updater" appears on the display.
Connect the computer to the GT-1000CORE's USB port by a USB cable.
Open the "GT-1000CORE" drive folder in your personal computer.
With Windows
Within My Computer (or Computer), open "GT-1000CORE" (or Removable Disk).
With macOS / OS X
On the desktop, open the "GT-1000CORE" icon.
Copy (drag and drop) the "GT-1000CORE_UPA_up.bin" in the "gt1000core_sys_v101" folder into the root directory of the "GT-1000CORE" drive.
After the copy has been completed, unmount or remove the drive on your computer.
With Windows
Right-click on the "GT-1000CORE" icon in My Computer (or the "Removable Disk (*:)" icon) and execute "Eject."
With macOS / OS X
Drag the "GT-1000CORE" icon to the Trush icon in the Dock.
Disconnect the USB cable.
The message "Execute update ? ([WRITE]: execute)" will appear on the display.
Press [ WRITE ] button to start the update process.
The message "Update completed. Turn off the GT-1000CORE." will appear on the display when the update process completes.
Turn the GT-1000CORE power off.
Follow the procedure for verifying the version to verify that the version has been updated.
