gt100 type preamp list
Started by colluluigi, August 03, 2020, 11:29:41 AM
colluluigi
Hello
I just bought a gt100 but I have a problem when I select a TYPE of PREAMP the drop-down list moves all the time and I have a hard time choosing
it is normal for you or it is a fault of my gt100
Thank you for your reply
Welcome to the group colluluigi!  :)
I would say that is not normal.
Is it connected to a computer?
Most likely a faulty knob pot on the GT-100.
You might need to give the knobs a good 'work out' to clean any internal build up of dust.
colluluigi
colluluigi
Quote from: gumtown on August 03, 2020, 05:14:55 PM
I have had it for 2 days I don't think the knob are already dirty
Quote from: colluluigi on August 03, 2020, 10:28:00 PM
You brought it new?
if the Amp selection list is scrolling by itself without user input, and the GT-100 is new, it has a fault with the menu rotary encoder.
Take it back to the store for a exchange or refund.
pbognar
Quote from: colluluigi on August 03, 2020, 11:29:41 AM
Hello
I remember this happening to me once and I seem to recall the solution was to perform a factory initialization.
pauloshure
Reset it and test it again, if it doesn't work try the gt-10 self-test..with it turned off volume to minimum and volume pedal to minimum, hold down the right arrow and the write button, this will enter the Test mode for it, choose test button vr360..if all are without defect it will appear ok..any result outside of that is defect.
