SY-1000 - Pink Floyd - On The Run
Started by Nobulusprime, July 25, 2020, 04:06:11 PM
Nobulusprime
So, I had a go at this iconic synth track - 'Silence in the studio!'
This is a live take, all 'live' no overdubs (only 1 take) no apologies, but it should show the possibilities in more able hands  :) There's a lot of mapping going on and assigning going on (there could be more that I may add) so it's best to read the following so it doesn't sound like a train wreck!!
It uses 3 x Dynamic synths and the normal pick up:
Dynamic Synth 1
- Provides the sequence 'hi hat' rhythm (with accents) press CTL-1 to hold this sequence *Note -it only plays on the A string!
Dynamic Synth 2 - Provides the main sequence - Play E on the 7th fret of the A string press CTL-2 to hold.  Again this is loudest on the A and E strings. *Note This sequence volume is mapped to the GK volume control
This sequence is modified with Exp 2 mapped to the cut off and resonance as well as a wah pedal (cry wah) for extra resonance boosting
* Note this is pedal works in reverse (fully depressed - no effect) mainly because it is used for dynamic synth 3
Exp pedal 1 is mapped to the LFO2.
Dynamic Synth 3 -
Doppler effect, with pan and filter effect on Exp pedal 2 *Note -it only plays on the E string! Obviously Exp pedal 2 is doing other stuff but it works fine in context!
Normal pick ups input is put through a slow gear an amp model and some delay * keep Your regular guitar volume down until you need to use it!
[soundcloud]https://soundcloud.com/nobulusprime/on-da-run-boss-sy1000-live-take[/soundcloud]
Could you possible re-save another copy of this patch, it unfortunately seems to be an empty liveset with no patch inside it.
Nobulusprime
Quote from: gumtown on July 25, 2020, 04:13:56 PM
I've saved it again... hopefully that should work now, let me know if not. I've added some extra 'performance'/assignment details too!   :)
So here's a rushed video for a patch I made to emulate On the Run by Pink Floyd (see patch exchange) - I wanted to go into more detail about it but I just ran out of time... so all of the promises of more in depth work will have to wait! But, you get the idea from this. A career on YouTube does not await me... yet!
This video ought to sell about 250,000 SY-1000 units to stoners in their 50s & 60s who want to trance themselves pretty hard for hours & hours...
The perfect shelter-in-place activity.
Nobulusprime
#5
I have updated and improved this patch here - essentially the same but the filters now work better and the tempo is slightly slower like the original!
I have a confession...
I bought a 2nd EV5 just for this patch...   ;D
I am not ashamed...
This is my favorite SY-1000 patch so far.
Yep.  Same "holy crap he actually did it" feeling as that classic VG-99 patch for Shine On You Crazy Diamond, where you can hold the chord for the spacey wine glass keyboard & solo over it...
Between this and the Ozric Tentacles sequencing I think the SY-1000 has potential that some of the early adopter/sellers had no clue was there.   With what I've discovered mine is near my VG-99 in the collecting of GK gear I'm keeping (along with the GP-10).
Antonuzzo
This inspired me to have a go too! The only think I've used for this is a Roland JX-03 Boutique module – a recreation of the JX-3P that was used to power the GR700. Well, a wee bit of echo too.
https://soundcloud.com/anthony-oneill-129798087/on-the-run
roachone
Picking jaw up from the floor. Holy crap that's good!
roachone
Now have a SY 1000 on the way.... ;D ;D ;D ;D ;D ;D
roachone
Just a follow up. I got it, and I love it!! Yeah, the editor is slow and crappy but I know of no other $1000 piece of equipment that will do what this does. Seems endless what can be achieved with this processor. Do hope Boss fixes the editor.
Quote from: roachone on August 28, 2021, 10:10:27 AM
swap over to Gumtowns SY-1000 Editor
https://www.vguitarforums.com/smf/index.php?topic=28906.0
roachone
I use his editor also, but I guess I'm use to the layout from Boss (had GT 1000 and many other Boss pedals) maybe I will take a spend a day or 2 using just his editor. Still think Boss should fix theirs. Thanks though for the suggestion.
