Re: Donner Circle / Mini Triple Loopers - Rotary Progress display with minutes
Started by admin, July 25, 2020, 09:31:09 AM
Donner Circle Looper  - Stereo,  Time progress bar Display Drum Machine
*2 in 1 Looper&Drum Machine - 44.1kHz 24bit high-quality looper and drum machine .100 different drum grooves from 10 unique music styles. 10 types of metronome settings to choose from
* EXT CTRL function supports external footswitch control (purchased separately)
* Up to 4 minutes of recording time per each track,40 preset slots,and 160 minutes total recording capacity
*NEW editor software  - Supports import/export recording via USB with editor software .Recording saved automatically,even after CIRCLELOOP is powered off.You can download the software from the official website
* Time progress bar Display - The display can show the time progress.So that you can focus on playing better.The detail of recording is displayed by the progress bar on the screen .
* Double Footswitch Looper Pedal - CIRCLE LOOPER has both LOOPER and RHYTHM modules.Users can Switch between LOOPER and RHYTHM by pressing both foot switches simultaneously.The LED of LOOPER(blue) and RHYTHM (red)will Indicate current module.
$69
https://tinyurl.com/y2742dd7
Donner Triple Looper Guitar Effect Pedal with Time Progress Bar Display 3 Slots for Saving Loop Tracks
* Convenient compact size, suitable for any music style.Straight forward design.
* Record/play/dub/stop/clear by one single footswitch
* True bypass.
* 3 slots for saving loop tracks.Automatically save recorded files even the unit is powered off
* Unlimited dub tracks. Up to 30 min each track.
* The sharp-looking loop indicator displays the current loop Mode (Rec/overdub/play)
The display can show The time progress.So that you can focus on playing better
https://tinyurl.com/y44s3mpq
