GP-10 - Two AC Guitars with variable room
Started by motetito, June 22, 2020, 07:44:56 PM
motetito
I was playing and exploring parameters used by other members and found a interensting one about using REVERB for create a variable room size, almost like change close to open micked spaces or something like that (you know what i mean).
So i created one patch with a 00028 Martin with a variable room controlled with the GK Vol. from a closed mic mono type thing to an open stereo type sound. I find this setup ideal for recording while you can change the space quickly. CTRL 1 switch 12st and CTRL 2 switch to openE. a EXP2 setup is create to change DELAY E. Level.
The other patch is created with a different AC sound but with the same GKVol behavior.  CTRL 1 switch to ALTTune CAPO like and you can change the capo with EXP2 from +1 to +5 in semitones. CTRL2 switch to FXDelay.
Hope you enjoy.
Menos es más...Tocá con el corazón.
motetito
