GT-1 - up and down assigned to system in Pref, but change with each patch
Started by Alathea_Squared, March 03, 2020, 04:43:38 AM
Alathea_Squared
I have up and down assigned to SYSTEM in Menu preferences, but when I change patches up and down change to something else. Is UP and Down not assignable system wide? I want to use up and down as FX1 and FX2 on all patches system wide.
"'Cause no matter where you go, there you are."
Yes UP and DOWN are assignable system wide.
easy to do using GT-1FxFloorBoard editor as all the settings for it are all under the CTL/EXP page tab.
In Boss Tone Studio editor, open the SYSTEM tab (bottom of page right) and select SYSTEM.
then choose the PREFERENCE tab.
Change UP and DOWN to SYSTEM.
close that page,
then select CTL/EXP,
scroll across to the far right of the page where UP and DOWN options are hidden off the page,
select FX1 and FX2 for the respective pedals, and TOGGLE for both.
Alathea_Squared
Quote from: AlexDAV on January 09, 2024, 10:29:22 PMHelp! UP button doesn't work!
Most likely a setting in the GT-1 System/Pedals/Control functions (there about) menu for "UP PEDAL FUNCTION"
If it was accidently changed to do something else or set to 'off'.
Look in that menu for the Up pedal setting.
