Looking for patch clone from SY-300
Started by Kevin M, February 09, 2020, 10:01:28 AM
Kevin M
I have a patch request for those of you SY-1000 owners who also have the SY-300. I previously had one and didn't bond with it, so I sold it. However, I started recording something and have a track where I used the Dripstone Cave patch from the 300. If anyone can get me in the ballpark of that patch for the 1000 - either by description, or by patch clone - I'd really appreciate it!
BROCKSTAR
OSC 1 - OFF until CTL 1 is engaged
OSC 2 - ON
OSC 3 - ON
OSC 1
OSC 1 wave/pitch
sin waveform
patch +12
fine 0
pitch env attack 0
pitch env depth 0
pitch bend depth 0
pitch bend ctl 0
OSC 1 FILTER/AMP
filter type LPF
filter slope -24db
filter cutoff 87
filter reso 40
filter env attack +50
filter env depth +20
amp env attack 0
osc 1 level 100
osc 1 pan center
OSC 1 LFO
LFO1 OFF/ON is off
lfo1 waveform sqr
lfo1 rate - not sure what that note is but if you need me to take a pic of it i can, just let me know
lfo1 dynamic depth on
lfo1 pitch depth 0
lfo filter depth 92
lfo1 amp depth 100
lfo1 fade time 0
lfo2 OFF/ON is on
lfo2 waveform sin
lfo2 rate 31
lfo2 dynamic depth off
lfo2 pitch depth 1
lfo2 filter depth 50
lfo2 amp depth 50
OSC 1 SEQUENCER
OFF/ON is ON
depth 60
loop length 15
All steps 0
OSC 2
OSC 2 wave/pitch
waveform sin
pitch +12
fine 0
sync off
ring off
pitch env attack 0
pitch env depth 0
pitch bend depth 0
pitch bend ctl 0
OSC 2 FILTER AMP
filter type bypass
filter slope -12db
filter cutoff 60
filter reso 18
filter env attack +30
filter env depth +25
amp env attack +30
osc2 level 100
osc2 pan center
OSC 2 LFO
lfo1 off/on is on
lfo1 waveform sin
lfo1 dynamics depth on
lfo1 pitch depth 0
lfo1 filter depth 50
lfo1 amp depth 26
lfo1 fade time 19
lfo2 off/on is on
lfo2 waveform sqr
lfo2 rate - not sure what that note is but if you need me to take a pic of it i can, just let me know
lfo2 dynamic depth on
lfo2 pitch depth 0
lfo2 filter depth 45
lfo2 amp depth 60
lfo2 fade time 0
OSC 2 SEQUENCER
link sw is off
off/on is off
depth 0
loop length 16
All steps are 0
OSC 3
OSC 3 wave/pitch
waveform pwm
pitch 0
fine is moving back and forth between -3 and +14
pulse width 50
sync off
ring off
pwm env attack 0
pwm env depth 0
pitch env attack 0
pitch evn depth 0
pitch bend depth 0
pitch bend ctl 0
OSC 3 FILTER/AMP
filter type LPF
filter slope -24db
filter cutoff moving back and forth from 9 to 60
filter reso 20
filter env attack 0
amp env attack 0
osc3 level 80
osc3 pan center
OSC 3 LFO
lfo1 off/on is on
lfo1 waveform sin
lfo1 rate 16
lfo1 pitch depth 0
lfo1 filter depth 34
lfo1 amp depth 0
lfo1 pwm depth 0
lfo fade time 0
lfo2 off/on is on
lfo2 waveform sin
lfo2 rate 50
lfo2 pitch depth 0
lfo2 filter depth 0
lfo2 amp depth 0
lfo2 pwm depth 0
lfo2 fade time 0
OSC 3 SEQUENCER
link sw is off
off/on is off
depth 0
loop length 16
All steps is 0
OD BLOCK
type OD-1
drive 80
tone +20
level 30
bottom 0
direct level 0
solo off/on is off
solo level 50
amp off/on is off
ns off/on is off
ns thresh 30
ns release 30
ROTARY BLOCK
speed select fast
rate slow 32
rate fast 44
depth 68
rise time 50
fall time 50
effect level 50
COMPRESSOR BLOCK
type hi-band
sustain 69
attack 73
effect level 57
tone +38
DLY+REV BLOCK
delay type analog
delay time - not sure what that note is but if you need me to take a pic of it i can, just let me know
delay feedback 40
delay effect level 90
delay high cut 2.50kh
delay direct level 100
reverb type plate
reverb time 4.5s
reverb pre delay 110ms
reverb effect level 80
reverb low cut 160hz
reverb high cut 2.00khz
reverb density 8
reverb direct level 74
Kevin M
BROCKSTAR
Quote from:  Bluesbird on February 09, 2020, 12:32:12 PM
Kevin, if you download Tone Studio for the SY-300 you can see all of the settings for each patch (not possible with the GT-1000, or SY-1000 without having device connected). You can also import patches into the VG-99 editor to clone patches.
Ugh why didn't I think of that instead of typing for 20 mins lol. Oh well haha.
Kevin M
Oh, I'm so sorry.  I didn't realize that BTS for the SY-300 had an offline mode.  Much thanks, though, to you Brockstar!
BROCKSTAR
mchad
Dripstone Cave was an excellent patch. Pretty sure I used it on something. Thanks for bringing it back.
