Katana Assigns
Started by Blueswaite, February 04, 2020, 03:51:03 PM
Blueswaite
Hope this is correct forum. I have a patch set up for GA-FC pedal 2 I'm controlling speed of rotary. Pedal 1 I'm controlling rotary level with a min and max setting problem is it is also controlling booster volume how do I prevent it from doing that
Is the "Assign" > "GAFC 2" > "Booster" set to "Preset".
The only other option if that does not work is the set the Booster assign to something unused with the min and max levels set the same,
to the same parameter setting value used in the Booster effect, so GAFC 2 will not affect the value..
Blueswaite
Thanks I'll check it   I have the fx switch foot controller shuts the rotary effect off  and I have a nice od main patch setup but when I turn rotary on volume is either dropping the booster or amp volume
My goal is to have a nice od amp booster setup and have a lite rotary effect Example some of Stevie ray vaughn stuff 1st control pedal control only rotary volume and 2nd control pedal control the rotary rate.
I'll check out your suggestion tomorrow
Blueswaite
Ended up taking Katana back and getting Blackstar HT40 MKII
Kantana did have some nice sounds Blackstar fit my needs better
Blueswaite
Blackstar didn't workout sticking with Katana Artist
