SY-1000 - Boss Tone Studio for SY-1000
Started by admin, January 15, 2020, 05:51:03 AM
https://www.boss.info/global/support/by_product/sy-1000/updates_drivers/5ee52836-c697-46b9-bffc-da4b059d0f5d/
UPDATE HISTORY
[ Ver.1.0.1 ] JAN 2020
Bug Fixes
When ASSIGN TARGET has been edited on the SY-1000, the MIN and MAX values in the ASSIGN list in BOSS TONE STUDIO sometimes show incorrect values.
When ASSIGN TARGET has been edited on the SY-1000, the ASSIGN Detail View window in BOSS TONE STUDIO sometimes disappears.
When a factory reset is carried out on the SY-1000, PATCH LIST in BOSS TONE STUDIO sometimes fails to be updated automatically.
After the screen has been switched in BOSS TONE STUDIO, the [ DYNAMIC SYNTH - SEQ : SEQ LENGTH ] value sometimes fails to be updated correctly.
Anyone can download and install Boss Tone Studio for SY-1000 and run in OFFLINE MODE  - and explore ALL SY-1000 Functions
https://www.boss.info/global/products/sy-1000/downloads/?fbclid=IwAR2MkIyfDwBgfxyB_b-TJD_VR4biRPKnk0Rl26nNzAVHeiZ-ImaK2ovTucg
See attached for Boss Tone Studio for SY-1000 Users Manual(pdf)
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=27135.0;attach=20106
BOSS TONE STUDIO FOR SY-1000 VER.1.0.0 FOR WINDOWS
Please refer to the "Using BOSS TONE STUDIO for SY-1000" for detailed information in the [ Owner's Manuals ].
DOWNLOAD AND EXPAND THE ARCHIVE FILE
Download the file named "bts_sy1000_w100.zip".
The downloaded file is an archive file in zip format.
Right-click to select Extract All, and then follow the instructions.
HOW TO INSTALL
Going into the bts_sy1000_w100 folder created by expanding bts_sy1000_w100.zip and double-clicking BOSS TONE STUDIO for SY-1000 Setup.exe starts installation.
Thereafter, follow the on-screen installation instructions to proceed with installation.
When the "The installation was successful" message appears, click [Close] to finish.
STARTING THE APPLICATION
Connect SY-1000 and computer with USB cable.
Turn on SY-1000.
From the computer's "Start" menu, select "All Programs" -> "BOSS TONE STUDIO for SY-1000" -> "BOSS TONE STUDIO for SY-1000."
Selection screen of connecting device will appear for the first time you run the software. (After the second time running, the device will be chosen automatically.)
Select SY-1000 and click [ OK ].
* The device can be changed from the SETTING.
* After starting the application, if connecting BOSS TONE STUDIO for SY-1000 and the SY-1000 is not possible, then in Windows 10, set "Allow apps to access your microphone" to "On."
Click [Start], then [Settings].
Click [Privacy].
Click [Microphone] on the left side.
The microphone setting is displayed.
To change the setting, move the "Allow apps to access your microphone" switch to "On."
Close the window and quit Settings.
SYSTEM REQUIREMENTS
OS
Microsoft(R) Windows(R) 10
Microsoft(R) Windows(R) 8.1
* Internet connectivity is required for using functions of TONE CENTRAL. (Please note that you might be charged for packet fee depends on your connectivity service.)
* This software has been found to work on typical computers that meet the above requirements, but we do not guarantee that it will operate on all such computers. Please be aware that differences in design or conditions of use may produce differences in the processing power of otherwise similar computers.
Each "INST" Block when set to E Guitar has its own AIRD AMP/CAB
- so if all "INST" blocks are set to "E Guitar" and you engage the Normal Guitar block  - you could be running up to four simultaneous  AIRD AMP/CABs at same time
And each INST Block has its Own Harmonizer
Assign Manual Mode Function assignment for lower 4 Footswitches
BROCKSTAR
#5
I hope they fixed the saving presets to computer feature that sucked in the sy-300 app.
arkieboy
So Tone Studio allowed me to drag the send/return to the first position in the regular guitar chain, which I think means we can use the send/return loop as an unaffected guitar out.  Moreover just by moving its position between patches you could swap from your normal guitar to a modelled guitar if you were using the SY with - say - a Helix.
Nice!
mooncaine
#7
I'd love to look it over, but I can't run it on my Mac.
Doesn't install on mac OSX 10.12.
Quote from: mooncaine on January 15, 2020, 10:48:32 AM
Doesn't install on mac OS 12.x
And Neither can I use with any of my Macs - as I'm not moving from OSX Yosemite
https://www.boss.info/global/support/by_product/sy-1000/updates_drivers/de4281c9-b329-47fc-85da-18b3e9524dd8/
SYSTEM REQUIREMENTS
OS
macOS 10.13 / macOS 10.14 / macOS 10.15
Boss Tone Studio for SY-1000 for Windows
SYSTEM REQUIREMENTS
OS
Confirmed it can also run fine on Win7 64
Upon 1st launch,  it takes up to 30 seconds to establish if the SY-1000 is present of not present  - but eventually I see the pop up screen
Quote from: arkieboy on January 15, 2020, 07:03:08 AM
So Tone Studio allowed me to drag the FX S/R Loop OUT  to the first position in the regular guitar chain, which I think means we can use the send/return loop as an unaffected guitar out.  Moreover just by moving its position between patches you could swap from your normal guitar to a modelled guitar if you were using the SY with - say - a Helix.
Nice!
Launch BTS for SY-1000 in OFFLINE Mode to explore the signal re-routing options
External FX Loop on 1/"4 Output to run third party FX
SUB OUT  on 1/"4 Output to run third party MFX ( Kemper, Helix) in Parallel
ReRoute the SUB Output  placed after INST1 in the Modeling section
Quote from: admin on January 15, 2020, 10:50:36 AM
SYSTEM REQUIREMENTS
OS
I'm not moving from Yosemite either
but a bootable external hard drive with OSX 13 on it should work , right ?
I kept 10.6 and had a botable HD with 10.10 when SY-300 came out.
It had only drivers etc from Yosemite
( still have and uses 10.6 for mastering etc a lot of the time )
Is there a hack whereby you could run on a Windows 7 32×? Maybe a virtual 64?
Quote from: chrish on January 15, 2020, 01:58:10 PM
I never recomend Win7 32  - very hostile OS which nothing runs on
I have a few machines that run native Win 7 64  - that runs well.
Could run VMWare Win7 64  - but Roland / Boss does NOT recommend it
Virtual machines can not run on a host system of less bit architecture (64bit wont run on a 32bit host).
32bit windows is also a dead end. It does not support enough RAM either, a 4gb vm requires a minimum of 8gb ram on the host system.
I googled Steve's responce and found out that machines over 10 years old likely do not have the 64-bit capable processor that you mention.
That would be me. Maybe time for a new confuser. I've already had to do a few fixes to one of the mouse type buttons and CD tray on the Toshiba Satellite.
Quote from: gumtown on January 15, 2020, 03:57:56 PM
Its been about 8 years since i had a laptop with a builtin optical drive.
Something with an intel 8th generation i5, 16gb ram, and 500gb ssd would be a minimum spec for a reasonzble laptop.
romero
#18
All loaded and checking out the layout and functionality, It's rather comprehensive and seems better than the  gp 10 version. I certainly hope they add IR loading like they did for the GT1000
Harmonist - Stereo  w/ Two User Assignable scales
Not to be confused with
Stereo Pitch Shifter
There are 10 GK User memory slots  - to support 10 different unique GK Guitar  / Bass / Instrument Settings
Observe the Normal Input includes Compressor on/off, Attack, Sustain, Level, Sensitivity, EQ Low and EQ High
Typical VG-99 class GK Hex PU Input Settings
DYNAMIC Synth String Pan / Level
DYNAMIC Synth User Alt Tuning and User Pitch Bend Range
Pitch 654321 refer to Strings 654321(Low E to high E)
DYNAMIC Synth - OSC TYPES
DYNAMIC Synth with Two User Assignable Arpeggiator Sequencers
DYNAMIC Synth Layer Note Range Assignment
Quote from: shikawkee on January 30, 2020, 11:43:02 AM
Oh and as I posted on FB, has anyone mentioned that updating firmware etc. in the future via Tone Central would be a cool thing to have?
Common wish with ALL current Boss units which employ Boss Tone Studio
At least they migrated away from relying on Adobe AIR for the underlying infrastructure on latest BTS releases
Also the System Version screen only reports the version of Boss Tone Studio
It never queries and reports back what SY-1000 Firmware version you are running - must do that direct on the unit
And Running BTS "OFFLINE" defaults to GUITAR MODE , SY-1000 must be physically connected to run BTS in BASS MODE
You can swap the order of all effects
FX1, FX2, FX3 are most versatile - but the COMP, DS (Distortion) , Chorus, Master Delay and Reverb can each be changed to different Types too
Download Boss Tone Studio for SY-1000 - run in OFFLINE MODE - Double Click on each Block to Edit and see all options for each block https://i.postimg.cc/fM5jHrDB/BLOCK1.png
The SY-1000 Reference Manual Describes All FX types
Here are the DS Block Distortion types
"Chorus has a few types too
FX1 , FX2, FX3 have the most options
And you can Move FX1, FX2, FX3 to be in the Normal signal path
Output EQ Settings
