Headrush - FAQ
Started by admin, October 29, 2018, 08:59:53 AM
IMPORTANT ARTICLE for all HEadrush owners
TROUBLESHOOTING CLASS COMPLIANT USB DEVICES
https://www.headrushfx.com/kb/article/2304
https://www.headrushfx.com/kb/article/2280
and read both the Quick Start PDF, and Owners Manual -  because important concepts explained in one, are omitted in the other ( must read Both)
and study the Headrush Knowledge base and FAQ
- there's  a lot more info at the Headrush web site today than existed just  6 months ago  - dont miss out
drill down and navigate all the links and learn
What are Scenes?
A Scene is a combination of models that can be turned on or off with a single footswitch. When the footswitch assigned to that scene is pressed, multiple models included in that scene will turn on or off depending on how they are assigned. To set and edit scenes for a footswitch, go to the the Hardware Assign page and tap Toggle/Hold/Scene. Here you can choose models assigned to that scene and whether they turn on or off when the scene is activated.
And Yes - Helix has deeper and more of everything - control, effects amp models, FX Parameters -   - but that does not stop the Headrush from delivering what I need most at my gigs
FWIW - in my arsenal  - the best external expression pedal for Headrush is the M-Audio EX-P
(which makes sense - since InMusic Owns both Headrush and M-Audio)
https://m-audio.com/products/view/ex-p
flip it over and set the Mode switch to "OTHER"
This pedal provides linear response, 1/2 way travel on EX-P pedal corresponds to 50% level of assigned Headrush parameter.
By Contrast  - the Headrush with Boss EV-5 as external expression pedal had reduced effective range,  1/2 way travel on EV-5 pedal corresponds to 20% level of assigned Headrush parameter.
FWIW - here is a EX-P schematic
Artist Presets w/ patch downloads after registering your Headrush
https://headrushfx.com/artists/
Tutorials
http://fiercemuleproductions.com/headrush-pedal-board/
Knowledge Base
the big Headrush has already obtained seven firmware updates
HeadRush Pedalboard
Latest Firmware Version: 2.1
Just unzip the FW 2.1 update zip file and read the PDF
Headrush Changes
Firmware Version 2.1
• Added 3 new amp models to the Amp category:
o 99 PV51 II LEAD
o 99 PV51 II CRUNCH
o 99 PV51 II CLEAN
• Added 140 new HeadRush Exclusive Cab IRs (impulse responses) to the IR category, based on the
following cabinets:
o 60S412A
o WHITEMOON112C
o WHITEMOON112OB
o JR112
o MKBASS212
o TREAD212
o TWIN212OB
• Added 3 new FX to the Expression category:
o CHORD WHAM
o FEEDBACK
o TIME WARP
• Added 2 new FX to the Reverb/Delay category:
o REVERSE DELAY
o PITCH DELAY
• Added DROP TUNE to the Modulation category.
• Added ANXIETY OD to the Distortion category.
• Added NOISE FILTER to the Dynamics/EQ category.
• Added the ability to save and load loops.
• Added the ability to configure scenes to load block presets.
• Added the ability to sort impulse response files using subfolders created in USB transfer mode.
• Added the ability to select lower intervals while using the SMART HARM effect.
• Added the ability to control the device using external MIDI CC messages.
• Minor bug fixes, DSP optimization and UI improvements.
Release Date: October 18, 2018
Changes
Since Firmware Version 2.0.0
• Added 7 new amp models to the Amp category:
o 65 BLACK PRINCE
o 65 BLACK PRINCE REV
o 66 FLIP BASS
o 82 LEAD 800 50W
o 82 LEAD 800 TS MOD
o 85 M-2 LEAD CAP MOD
o 92 TREADPLATE RAW
• Added 160 new HeadRush Exclusive Cab IRs (impulse responses) to the IR category, based on the
following cabinets:
o 60S 412
o BIRCH 115
o BIRCH 410
o BLACK LINE 810
o FAWN 212
o TANGERINE 212OB
o TANGERINE 412
o TREAD 412
• Added 3 new FX to the Modulation category:
o SMART HARM
o TRON FILTER
o RING MOD
o SHIMMER
o AIR DELAY
• Added AUTO SWELL to the Dynamics category.
• Enhanced the Setlist feature by adding the following:
o Added the ability to group preset rigs into Songs within a setlist.
o Added a new footswitch mode, Song View.
o Added Classic and Advanced options for viewing setlists on the 7" touch screen in Song
View.
• Added the following options to the Global Settings page:
o Added the option to reverse Hybrid View.
o Added options to customize the overall color scheme used on the touch screen and LEDs.
• Added the ability to save in Hands-Free Mode by using a footswitch.
• Added the ability to toggle reverb and delay tails per effect within a rig.
• Added the ability to save expression pedal state (A/B) per rig.
• Added the ability to touch and drag to navigate parameters displayed on the 3 parameter knobs.
• Additional DSP optimization and UI improvements.
Firmware Version 1.2.1
• Minor bug fixes.
Firmware Version 1.2.0
• Added Octaves effect to the Modulation model category.
• Added Global EQ settings to the Global Settings page.
• Added the ability to quickly select and audition impulse response files in Hands-Free Mode using footswitches.
• Added the ability to select IR (1024) as an alternate output on the Global Settings page.
• Significantly reduced rig-switching time.
• The current view (Stomp View, Rig View, Hybrid View, or Setlist View) is now retained when you power
off HeadRush Pedalboard.
• Minor bug fixes and DSP optimizations.
Firmware Version 1.1.1
• Minor bug fixes.
Firmware Version 1.1.0
• Added 59 Tweed Prince to the Amp model category.
• Added Air Vibrato effect to the Modulation model category.
• Added More Wah effect to the Expression model category.
• Added Panner effect to the Expression model category.
• Added Gate effect to the Dynamics/EQ model category.
• Added the ability to import .tfx (Eleven® Rack) presets.
To import a .tfx preset, click and drag it to the Rigs folder when connected to a computer and the
HeadRush Pedalboard is in USB Transfer mode, and then tap Sync.
• Added the ability to customize the text on an OLED screen for a footswitch set to Stomp Mode.
To change the OLED text for a footswitch in Stomp Mode, enter the Hardware Assign page, and
then tap the outlined box that shows the current OLED text for one of the 8 footswitches.
• Added Scene feature, which is the ability to assign a single footswitch to control the On/Off parameter
for multiple models.
To assign a single footswitch to control the On/Off parameter for multiple models, enter the
Hardware Assign page, and then tap the Toggle/Hold parameter for one of the 8 assignable
footswitches until it says Scene. Then, tap the Edit text that appears on the footswitch to set which
models will be turned on/off when pressing the footswitch.
• Added the ability to make fine adjustments in Hands-Free Mode by using the two bottom-right
footswitches labeled – and +.
• Added the ability to delete models from the main screen by dragging and dropping them onto a Drag
to Delete bar that appears at the bottom of the screen.
• Added the ability to select 44.1kHz as a sample rate for USB Audio.
• Added the ability to use a search bar for faster access to finding rigs while creating or editing a setlist.
Firmware Version 1.0.2
• Added Screen Lock feature. This feature disables the touchscreen, and gives you a simple interface
that shows your current rig name, setlist name, and a customizable image.
To customize the Screen Lock image, while the HeadRush Pedalboard is in USB Transfer mode, place
a .png, .bmp, .jpg, or .jpeg file named LockScreenLogo in the root directory of the HeadRush drive. We
recommend using a 800x400-pixel image (it will be automatically scaled to this size after transferring it).
• Added the ability to place the looper before or after your signal chain. This gives you the ability to
record a riff, and then place it before the signal chain so you can sculpt your rig's sound without having
to physically play the riff over and over again.
To set the looper's location, while viewing the looper on the touchscreen, turn the third parameter
knob (Loc) to place it before (Pre) or after (Post) the signal chain.
• Added ability to truncate impulse response (IR) files to 1024 samples. When your IRs are truncated,
they require fewer DSP resources, which frees up more resources to load additional models and/or IRs
to each rig.
To load a truncated IR, select IR 1024 instead of the normal IR setting when adding an IR to a rig.
• Added the ability to enable or disable confirmation messages that appear while changing your rig.
To enable or disable these messages, enter the Global Settings screen and set Reminders >
Confirm Unsaved to On (enabled) or Off (disabled).
• Added Side Comp effect to the Dynamics/EQ model category. This is a side-chain compressor effect,
which uses the HeadRush Pedalboard's effects return as the side-chain input.
Note: When this effect is in your signal chain, the FX Loop will be disabled.
Firmware Version 1.0.1
• Enabled USB audio recording and reamping features.
Important Note for Windows Users: Visit headrushfx.com/support and download and install the
latest Windows driver before using the USB Audio feature.
• Minor bug fixes.
My Headrush USB has been rock solid - using a Windows 8.1 laptop ( with the Headrush Win ASIO Audio Driver) for recording) or using a Macbook pro
What I do is power up the Win8.1 computer 1st, then powered up Headrush, then connect to computer via USB 2.0 cable
https://headrushfx.com/kb/article/2304
Then I enable the USB MODE I desire here
And if you are just loading patches - Turn OFF the USB AUDIO when NOT Recording
and ENABLE USB TRANSFER - which allows Headrush to act like a USB storage drive
https://headrushfx.com/kb/article/2344
IMPORTANT - During USB TRANSFER MODE, Since the Headrush shows up as a USB Drive on your Windows computer, upon completion of all data transfers (patches, IRs, etc) - you MUST EJECT the Headrush drive - or power down the computer 1st - then power down the Headrush, then remove the USB cable[/b]
Recording
https://www.headrushfx.com/kb/article/2338
When the HeadRush Gigboard's USB port is connected to your computer, you can select and use the HeadRush
Gigboard as a 24-bit audio interface, enabling you to play audio through it or to send its audio signal to the
computer. It can use sample rates of 44.1 kHz, 48 kHz, or 96 kHz.
Important Note for Windows Users: Before connecting the HeadRush Gigboard to your computer, download
the necessary ASIO drivers from headrushfx.com/support and install them.
To use the HeadRush Gigboard as an audio interface with your computer, open your computer's Control
Panel (Windows) or System Preferences (Mac OS), open its sound/audio settings, and select HeadRush
Gigboard as the device for recording/input and/or for playback/output.
The HeadRush Gigboard can send four separate audio signal channels to your computer. Before recording the
HeadRush Gigboard's audio signal into your digital audio workstation (DAW), select the channel/channels you
want to record:
1: the left channel of the master outputs with all active effects applied.
2: the right channel of the master outputs with all active effects applied.
3: a mono channel of the guitar input with no effects applied.
4: identical audio signal to 3.
The HeadRush Gigboard can receive four separate audio signal channels from your computer. The channels are
named and routed as follows:
1: the left channel of your computer's output audio signal, which will be sent directly out of the HeadRush
Gigboard's master outputs and phones output.
2: the right channel of your computer's output audio signal, which will be sent directly out of the HeadRush
3: a mono channel of your computer's audio signal, which will be sent back through the HeadRush Gigboard
(see Reamping below).
4: not used in this scenario.
Important: Remember to set your DAW's master outputs to be sent to 1/2.
Reamping
Reamping is a process that adds the tone coloration of an amp to a pre-recorded audio signal—in this case,
sending audio from your DAW through the HeadRush Gigboard and then recording it back into your DAW. This is
useful for saving time because you can change the sound of an already-recorded guitar track without having to
manually play the same part again.
To use the HeadRush Gigboard to reamp an audio signal:
1. In your DAW, make sure HeadRush Gigboard is selected as your audio interface for both recording/input
and playback/output.
2. Assign the output of the desired track to 3.
3. On the HeadRush Gigboard, tap the  button in the upper-right corner of the screen, and tap Global Settings.
4. In the Global Settings screen, tap Reamp next to USB Mode.
Also, make sure the Sample Rate is set to the same sample rate as the one in your DAW. To change the
Sample Rate, set USB Audio to Off first, select the correct sample rate, set USB Audio to On again, and restart
your DAW.
5. In your DAW again, create a new audio track and assign its input. For a stereo input signal, select 1/2. For a
mono input signal, select 1.
6. Locate the point in your track where you want to start reamping.
7. On the HeadRush Gigboard, select the rig, models, or other parameters to achieve the sound you want.
8. In your DAW, start audio recording. The track you want to reamp will be sent through the HeadRush Gigboard
and recorded into the audio track you created earlier.
http://www.mylespaul.com/threads/the-official-headrush-pedalboard-thread.402035/
Dude705 wrote>
It's too bad CaptainT got rid of the board as he experienced a DSP limit while creating a rig. Only if he would have known at the time that all he would have had to do was replace the 2048 IR with a 1024, and would have had more DSP to work with. Sounds like he enjoyed every bit of that board....wonder if he was ever informed...
 Headrush with firmware 2.0, when. I engage The Looper Mode the bottom row footswitches (left to right) say:
START RECORD INSERT PEEL MUTE TEMPO
To initiate a new recording I press the "RECORD" footswitch (The wide color bar above the "RECORD" oled label turns red, and the "START" oled changes to say "STOP"
IMPORTANT - To Stop recording and keep it - do not press STOP Footswitch
Instead press "RECORD" footswitch again , and now the recorded loop audio will commence playback, the "RECORD" oled will now say "OVERDUB", and the wide color bar turns yellow
The footswitch on far left can be used to toggle the Loop audio "STOP" or "START"
IF you press "STOP" the loop stops playback
IF you press "START" the prior recorded loop (using the steps above) will start playback
Strange they never mention the function of the "START or "STOP" foot switch in the Looper Instructions in the Headrush 2.0 Manual
Be sure the "MIX" and FDBK"(Feedback) settings match the LCD screen above
If Looper "MIX" is set to 100% - you will kill / mute the normal output sound
How to Reset  / Restore the Headrush
Factory Reset: Hold the 2 far right buttons down
(#6 top row & #12 bottom row) while powering ON
How do I restore the factory presets?
You can restore your factory presets by holding footswitch 11+12 (the two right footswitches on the bottom row) while powering on the HeadRush pedalboard. Keep holding these two switches until you see "Reverting..." displayed on the color LCD touchscreen.
Enable "CC" auto translate from Spanish to English on video above
https://www.thegearpage.net/board/index.php?posts/27440042/
Quote from: ssmug, post: 27440016, member: 2986Will the HR drive high-impedance headphones (e.g., Beyerdynamic 990 pro - 250 ohms)?
Yes - Headrush (big board - no experience with Gigboard) has the best internal  Headphone amp of all my modelers
But I will point out in an A/B test of Beyer DT880 (250 ohms) vs ATH-M50X (32 ohms)  - the ATH-M50X sound much better  -
Now available from Headrush, they have been adding free Artist packs of rigs:
Tracii Guns
Robert Gueringer
Dan Vadim Von
Nili Brosh
Javier Vinas
Dallas Molster
Dana Sharpton
Kelly Simonz
Quote from: Smashcraaft, post: 27560217, member: 175354AFAIK there are different approaches ongoing to program a tool to manage (tag, fav, rename (code names)) IR files. I am looking forward to see first results which should dive deeper than just renaming IR-files.
review these threads
http://headrushfans.com/Thread-IR-Block-presets-for-several-collections
http://headrushfans.com/Thread-Let-s-build-a-Tool-to-manage-IR
https://www.musiker-board.de/threads/organisieren-von-cab-sim-impulse-response-files-ir-files.682891/
https://www.thegearpage.net/board/index.php?threads/ir-workshop-a-tool-for-mixing-and-editing-impulse-responses-and-a-free-ir-pack.1862749/
Valdiorn wrote>
I've been working on a new side project for the last couple of weeks, and have just released the first alpha version to the public.
IR workshop is a free Windows application (7,8,10, 64-bit) for mixing, merging, converting, equalizing, stereo-spatializing and mangling impulse responses in every way I could think of.
Features:
Live preview of your impulse response with ASIO support
Mix, pan and filter any number of impulse responses
Convert between samplerates
Truncate files with minimum loss of quality
Multiple options for frequency and phase response, including:
Minimum Phase Transform
Frequency response smoothing and exciting
Apply randomization to frequency response
"Skew" the frequency response to simulate smaller/larger resonance frequency
High and Low-pass filtering
6 Band parametric equalizer
Stereo enhancement effects
...and many more
The application can be downloaded from Github at: https://github.com/ValdemarOrn/IRWorkshop
(If you want to give it a try, please be sure to read the instructions on the page on how to download and run the program)
There is a (possibly incomprehensible :))
https://github.com/ValdemarOrn/IRWorkshop/blob/master/Guide/Readme.md
user guide available which tries to explain all the features and sliders and what they do.
For basic operations like mixing and converting between samplerates, the software should be fairly straight forward. However, it can do much more, and to illustrate that I've used it to create a collection of completely synthetic impulse responses. These IRs were essentially made from thin air, using only IR Workshop. The collection contains both mono and stereo .wav files at 44.1Khz and 48Khz samplerates, with 256, 512, 1024 and 2048 sample length IRs included.
The reason I made this was to show off the capabilities of the software and it's ability to re-shape and sculpt the response of speaker cabinets. However, I ended up generating several IRs which sounded quite pleasant, so I thought I'd release them as an extra bonus.
Download Synthetic Cabinets on Github (Synthetic_Cabinets.zip)
https://github.com/ValdemarOrn/IRWorkshop/releases
The software is in very early alpha stages, but has been tested on a handful of machines and generally runs without problems, but do keep in mind that this is a very early release :)
I'd also like to pimp out my other projects; some of you may have seen the ADA MP-2 editor I built earlier this year. I've also built quite a few VST plugins, including an algorithmic reverb plugin, and a Randall RG-100 amp simulator
Check it out - http://valdemarorn.github.io/AudioProjects.html
New Headrush Pedal Board Manual version 2.1
https://www.headrushfx.com/assets/downloads/Pedalboard%20-%20User%20Guide%20-%20v2.1.pdf
change is on page 28 - Hands Free Mode
(removed this text)
"If you are using a double-amp and/or double-cab configuration (2X), use the 1^ v 2 footswitch to switch between the two."
https://www.thegearpage.net/board/index.php?posts/27748530/
MixMinisterMike wrote>
The request to have multiple FX assigned to a single footswitch has been brought up here several times.
I want to point out that unlike the Helix, the Gigboard can have switches assigned to scenes and other switches assigned to individual blocks. Scenes aren't a mode you are forced to switch in and out of completely - you can have scenes assigned to any switch and another switch can be an individual block on/off.
Might not address every scenario for every player, especially as there are only 4 onboard switches which leads to what Choptones does - the left two switches are assigned to scenes and the right two assigned to stomps, but this is certainly worth pointing out. I didn't understand this until I started deconstructing the Choptones presets and I realized - wait, this will let me assign multiple fx to a single switch and other switches can be individual block on/off.
http://headrushfans.com/Thread-Using-Bias-Irs-into-your-gigboard
For people owning BIAS there is a way to capture and get Bias Irs.
Of course only if you have bought Bias i think it's legit to use the IRs elsewhere.
You have first to import a sine sweep into your daw and process it thru the cab only.
Here : https://www.audiocheck.net/download.php?filename=Audio/audiocheck.net_hdsweep_1Hz_48000Hz_-3dBFS_30s.wav
Then export the result. You have to export a little bit of silence after the record.
Now get voxengo deconvolver here : https://www.voxengo.com/product/deconvolver/
Open and load as source the sine sweep used into your daw.
Load into "files to process" the result, check the MP transform and Process.
The result will be the IR, you can now load it into your gigboard.
https://www.thegearpage.net/board/index.php?threads/headrush-output-problem.2007574/page-2
Quotealex mansman said: ↑
How do you know the master at MAX is unity? I've tried looking into this and found no documentation on that for the HR. If this really is true then I guess I dont have an issue because with the master at MAX it did get fairly loud. Just not as loud and robust as direct into the Quilter. Maybe that's just the nature of modeling though?
poison7512 wrote>
1. Plug a guitar directly into a mixer and note the level when you play
2. Plug a guitar into the Headrush then into the mixer and play the same thing
3. Adjust Master Volume until the level matches
For me it's when the Volume is at MAX on a completely EMPTY Rig with the outputs set to AMP. The level is identical.
QuoteHeadrush - What song is the factory preset referencing?
http://headrushfans.com/Thread-Where-can-I-find-out-what-all-the-preset-rig-settings-repesent
All Guesses
001 HOW DOES IT FEEL = DO YOU FEEL LIKE I DO or Like a Rolling Stone by Bob Dylan
002 PERSONAL GURU = Personal Jesus
003 MODERN PLEXI
004 FOOD FIGHT = FOO FIGHTERS
005 SWEET HOME BRO = SWEET HOME ALABAMA by Lynyrd Skynyrd
006 PASSING LANE = LIFE IN THE FAST LANE by the Eagles
007 SHREDDIN CULT
008 SANDMAN = ENTER SANDMAN by Metallica
009 LIKE A BELL
010 CLEAN SHIVERS
011 MORE COWBELL = MISSISSIPPI QUEEN by Mountain or Don't Fear the Reaper by Blue Oyster Cult (from the SNL skit)
012 CRAZY TED = Cat Scratch Fever (et al) by Ted Nugent
013 INDUSTRIAL
014 X ROADS = Crossroads by Cream
015 JIM
016 BROWN 800
017 PURPLE BIKE
018 PURPLE SOLO
019 HEART PWNER = BARRACUDA or Owner of a Lonely Heart by Yes
020 SCARED ROBOT
021 RUN AWAY FAST
022 GHOST IN THE SKY = Spirit in the Sky Norman Greenbaum
023 SWELLA
024 ONLY TO BE = Still Haven't Found What I'm Looking For by U2
025 DADDY'S NEW BAG = Papa's got a Brand New Bag by James Brown
026 JUJU EYEBALL = COME TOGETHER by Beatles or Aerosmith
027 INSAIN TRAIN = CRAZY TRAIN by Ozzy Osbourne
028 GIMME A KISS = KISS- PRINCE
029 GIMME A SOLO = KISS- PRINCE
030 WHITE CLIFFS
031 BEASTLY STONE = Beast of Burden by Rolling Stones
032 SHELTER = GIMME SHELTER (intro/lead) by Rolling Stones
033 ROUTE 666 = HIWAY TO HELL or Route 66 by Rolling Stones
034 HEART RIFF = Heart of Gold by Neil Young
035 MY AIM IS TRUE = Elvis Costello
036 GENERATION ME = MY GENERATION by the Who
037 DON'T CRY = No Woman No Cry By Bob Marley/NOFX
038 SURF = The Ventures
039 SHOT IN RENO = I SHOT THE SHERIFF or Folsom Prison Blues by Johnny Cash
040 NUTHIN DOG = Hound Dog by Elvis
041 BLACK LAB = BLACK BETTY or Black Dog by Led Zep
042 DUSTY QUEEN = ANOTHER ONE BITES THE DUST by Queen
043 BOHEMIA SOLO = BOHEMIAN RHAPSODY by Queen
044 U WILL BE ROCKED = WE WILL ROCK YOU by Queen
045 SHE DON'T LIE = COCAINE by Eric Clapton
046 GEORGES WIFE = Layla by Eric Clapton
047 SUNSHINE = SUNSHINE OF YOUR LOVE by Cream
048 BLACK CURTAINS = White Room by Cream
049 TONIGHT WON = Wonderful Tonight by Eric Clapton
050 SWAMP BORN = BORN ON THE BAYOU by CCR (Creedence Clearwater Revival/John Fogary)
051 IT AINT ME = Fortunate Son by CCR
052 HEARD IT THRU = HEARD IT THROUGH THE GRAPE VINE by CCR
053 RIVER ROLL = Proud Mary by CCR
054 GIVE U MY LOVE = Whole Lotta Love by Led Zep
055 HOLY HOUSE = Houses of the Holy by Led Zep
056 PURPLE JAMES = Purple Haze by Hendrix
057 LIKE A FOX = FOXY LADY by Hendrix
058 HEY JOSEPH = HEY JUDE or Hey Joe  by Hendrix
059 WINDY MARY = Wind Cries Mary  by Hendrix
060 WAH VOODOO = VOODOO CHILD  by Hendrix
061 BROWNSTONE = Brown Sugar by Rolling Stones
062 HONKY TONK BLUES = HONY TONK Woman by Rolling Stones
063 GAS GAS GAS = Jumping Jack Flash by Rolling Stones
064 NOT SATISFIED = (I CANT GET NO) SATISFACTION by Rolling Stones
065 JOE'S DREAM = Dream On by Aerosmith
066 SWEET EMOJI = SWEET EMOTIONS by Aerosmith
067 ESCAPED BIRD = FREE BIRD by Lynyrd Skynyrd
068 BENCH SINNIN
069 BOOM X4
070 GREEN VEGGIES = Green Onions by Booker T and the MG's
071 MUDDY BLUES = Nights in White Satin by The Moody Blues
072 SUNRISE HOUSE = HOUSE OF THE RISING SUN by the Animals
073 JESSICA'S SOLO = JESSIE'S GIRL or Jessica by Allman Bros.
074 JOHN BE GREAT = JOHNNY BE GOOD by Chuck Berry
075 LIFE IS GOOD = Life's been Good So Far by Joe Walsh
076 WITH FRIENDS = WITH A LITTLE HELP FROM MY FRIENDS by Beatles/Joe Cocker or Theme From Friends by The Replacements
077 LITTLE THANG
078 PUMPIN UP
079 FIRE IN THE SKY
080 PREACHER SON = SON OF A PREACHER MAN b Aretha Franklin
081 GEORGIA BLUES
082 MISSING THRILL = The Thrill is Gone by BB King
083 TIED 2 THE POST = Whipping Post by Allman Bros
084 JUMP SWING
085 LINK ROCK
086 MDRN CHCKN PICK
087 ROCKABILLY
088 SWAMP
089 TEXAS BLUES
090 BALDWIN BURGER
091 TROW UR BOAT
092 10-CENT COMING = Pantera
093 10-CENT FLOOD = Pantera
094 10-CENT GATES = Pantera
095 10-CENT JUKEBOX = Pantera
096 COLD NOVEMBER = November Rain by Guns and Roses
097 NICE CHILD = SWEET CHILD O' MINE  by Guns and Roses
098 MR C'S LEAD
099 NO MORE CRYIN = No More Tears by Ozzy Osbourne
100 TONY'S METAL = Tony Iommi (Black Sabbath)
101 IRON MEN = IRON MAN by Black Sabbath
102 LUNAR BARKING = BARKING AT THE MOON by Ozzy Osbourne
103 BLACK FADE = Fade to Black by Metallica
104 ONE BALLAD CLN = ONE by METALLICA
105 ONE BALLAD = ONE by METALLICA
106 SAD TRUTH = Sad But True by METALLICA
107 DJENT DJENT = Meshuggah
108 GIRLS X 3 = GIRLS, GIRLS, GIRLS by Motley Crue
109 HOT STICKY = POUR SOME SUGAR ON ME by Def Leopard
110 IRON TROOPS = Iron Maiden
111 MEGA METAL = Megadeath
112 MOSH = Caught in a Mosh by Anthrax
113 RED RAIN = Red Rain by Peter Gabriel or Purple Rain by Prince
114 SLAUGHTER = Take Your Daughter to the Slaughter by Judas Priest
115 WIZARD METAL = The Wizard by Black Sabbath
116 TAKE ME HOME CLN = Take Me Home by Phil Collins
117 TAKE ME HOME = Take Me Home by Phil Collins
118 MARCHING BULLS = BULLS ON PARADE by Rage Against the Machine
119 PERFECT RX
120 RT95 LOVE SONG = Interstate Love Song by Stone Temple Pilots
121 WONT DO IT
122 XTREME ALIEN
123 HIPSTER JAZZ
124 KEEP BELIEVIN = DON'T STOP BELIEVING by Journey
125 LOVE SACRIFICE = Cold as Ice by Foreigner
126 SUMMER BOYS = BOYS OF SUMMER? or Don Henley
127 SUMMER SOLOBOYS OF SUMMER? or Don Henley
128 IF YOU SAY RUN = DANCE- DAVID BOWIE
129 IF YOU SAY SOLO = DANCE- DAVID BOWIE
130 BE QUIET N DANCE = SHUTUP AND DANCE WITH ME by Aerosmith
131 LITTLE OLD PLACE = Love Shack by B52s
132 LUKES BLUES
133 CALLIN BLONDE = CALL ME by BLONDIE
134 LA CORK ROCK
135 LA CORK SOLO
136 FUNKY BRUNO = UPTOWN FUNK or Bruno Mars
137 UP ALL NIGHT = LUCKY by Daft Punk
138 MOM SPAGHETTI = LOSE YOURSELF by EMINEM
139 RICHIE'S SHOT = Livin on a Prayer by Bon Jovi (Richie Sambora on guitar)
140 FUSION SOLO
141 SUNDAYS
142 SMOOTH LEAD = SMOOTH CRIMINAL or Smooth by Santana
143 FA FA FA FA FA = Psycho Killer by Talking Heads
144 SHOW ME = Show Me The Way by Peter Frampton
145 THRILLING SOLO = THRILLER by Micheal Jackson
146 POWER SLAPBACK
147 ILL BE WATCHING 1 = EVERY BREATH YOU TAKE by Police
148 ILL BE WATCHING 2 = EVERY BREATH YOU TAKE by Police
149 BLUES FLANGER
150 RED LIGHT = ROXANNE By Police
151 STRAY TOWN = ROCK THIS TOWN by Brian Setzer
152 80'S VEGAN
153 FULL FUZZ
154 PJ GRUNGE = Pearl Jam
155 SMELLY TEEN = SMELLS LIKE TEEN SPIRIT by Nirvana
156 MEMORIA = Memoria by Ghost
157 MUNKEY GRUNGE = IM A BELIEVER by the Monkees or Arctic Monkeys
158 MIGHTY MIGHTY = BRICK HOUSE by The Commodores or Mighty Mighty Bosstones
159 NO CRYSTAL BALL = Santeria by Sublime
160 UP THE FLAGPOLE
161 SPOKE IN CLASS
162 IRISH PRIDE = Pride in the Name of Love by U2
163 KEN'S FREQ OUT = What's the Frequency Kenneth by REM
164 OC SKA PUNK = No Doubt
165 IRISH NEW YEAR = New year's Day by U2
166 WOOHOO! = SONG 2 by Blur
167 DREAMY TWEED
168 CREEPY = Creep by Radiohead
169 APOLOGIES = SORRY/ I'M SO SORRY? or All Apologies by Nirvana
170 JALAPENO = Red Hot Chili Peppers
171 SURFIN LOBSTER = Rock Lobster by B52s
172 STADIUM ROCK
173 RB-RED ROCK
174 BALLAD PHASER
175 COUNRTY SOLO
176 FUNKY WAH
177 BORN AND WILD = BORN TO BE WILD by Steppenwolf
178 BRIGHT TO SEE = Too Bright to See, Too Loud to Hear by Under Oath
179 JAKE'S SOUL + Soul Man by Sam and Dave
180 100, 200
181 MARS SPIDERS = Ziggy Stardust/ Suffragette City/Queen Bitch etc... by David Bowie - Mick Ronson Era
182 STAYIN TOGETHER
183 STEEL REEL = Reeling in the Years by Steely Dan
184 DARK MAGIC = BLACK MAGIC WOMAN by Santana
185 HERE I COME = by Fergie
186 MEN ARE BACK = BOYS ARE BACK by Thin Lizzy
187 BAD BONES = BAD TO THE BONE by George Thorogood
188 BAHSTON = More Than Feeling (et al) by BOSTON
189 TEMPTING = Tempted by the Fruit of Another by Squeeze
190 SLY DANCE = Dance to The Music by Sly and the Family Stone
191 ROLLIN' PAPA = PAPA WAS A ROLLIN STONE by the Temptations
192 BRICK SOLO = ANOTHER BICK IN THE WALL by Pink Floyd
193 BRICK CLN = ANOTHER BICK IN THE WALL by Pink Floyd
194 SKA DROP = Pressure Drop by the Specials
195 SALLY RIDES = Mustang Sally by Wilson Pickett or Ride Sally Ride by Lou Reed
196 FUNKY LIGHT
197 TIGER'S EYE = EYE OF THE TIGER by Survivor
198 SOCK IT 2 ME = HIT ME WITH YOUR BEST SHOT by Pat Beneath
199 A BIG TEASER
200 CIGAR BAR = Cigar Song by Brad Paisley
201 TAKE A LOAD OFF = The Weight by The Band
202 CALI HOTEL F = HOTEL CALIFORNIA by the Eagles
203 CALI HOTEL W = HOTEL CALIFORNIAby the Eagles
204 PINK TIME = Time by Pink Floyd
205 I HAVE BECOME = Comfortably Numb by Pink Floyd
206 REVOFUZZ = Revolution by the Beatles
207 JUST FOR ONE DAY = Heroes by David Bowie
208 BROWN EYES = Brown Eyed Girl by Van Morrison
209 YOUR PET FUZZ
210 MOTHER MOTHER Mother by Danzig
211 FEELING SO GOOD = I FEEL GOOD by James Brown
212 DO WHAT YOU WANT = Lady Gaga
213 BETTER BIRDS
214 GET THAT FEELING = I Gotta Feeling by Black Eyed Peas or Let Me Take You Home Tonight by Boston
215 PY CLEAN = Peavey Amp Clean
216 PY DIRTY = Peavey Amp Dirty
217 WATCHING TIDES = Sittin on the Dock of the Bay by Otis Redding
218 NEED SOMEBODY = Need Somebody to Love by Jefferson Airplane
219 ROBBY'S FIRE = Light My Fire by the Doors (Robbie Krieger on guitar)
220 PRISONBREAK = Jail Break by Thin Lizzy
221 1 MORE CHANCE = Give me One More Chance by Exile
222 SAY YOU WILL = Shout by the Isley Brothers or Say You Will by Foreigner
223 PLEXI ROCK
224 CLEAN HEAVEN = Stairway to Heaven by Led Zep
225 WHAMMY SHRED
226 FUNK IT
227 FUSION ROCK
228 JAZZ UP
229 HEAVY ROCK LEAD
230 ROTORY BLUES
231 CREAMY STRAT
232 THE GRITT
233 REZNAS CHOICE
234 WELL DRESSED = Sharp Dressed Man by ZZ Top
235 CRUNCHPRESSOR
236 BITFIRE
237 ECHO PARK = Lost in the Echo by Linkin Park
238 DORIES BLUES
239 CLEAN DREAM
240 GET WET LATER
241 PEDAL DRIVE
242 BLACK
243 BLUE
244 BOG
245 CHIEF
246 HEAVY
247 HI-GAIN
248 MARK 8
249 MAYHEM
250 RECTANGLE
251 SOLD OUT
252 METAL 1
253 METAL 2
254 BLUES
255 PUNK
256 SOFT
257 HOME-AGE
258 BASS
259 FUNKY BASS
260 MOD METAL
261 ROCK BASS
262 SYNTH BASS
263 MIXIN BASS
264 SLAP BASS
The more time you spend with HeadRush (or any top-tier modeler), the more you'll learn.
Getting the desired result will be quicker/easier.
What's really cool (IMO) is that any techniques you learn can be applied to any of the modelers.
Even if you were to switch to the Axe-FX III in the future, what you've learned is directly applicable.
Another simple thing:
There's not a lot above ~7.5kHz coming out of a real guitar cab.
If you're hearing significant signal above 7.5kHz (too much top end), it'll sound artificial.
You can use a low-pass filter to remove these high frequencies.
This can be done with the HICUT parameter in the Cab/IR Block... or you can add a Para EQ (post Cab).
I've been using the HICUT parameter in the IR Cab Block (to conserve processing).
If you have a chance to use multiple modelers, you'll learn different things.
ie: The Axe-FX III has much deeper editing than other modelers.
Using the Axe-FX's more advanced parameters got me thinking about speaker compression.
Even though those parameters aren't on the Helix, HeadRush, etc... you can still try to emulate the effect.
Thinking about the Axe-FX III's new Cab block capabilities (each of the two Cab Blocks can load up to four Cab IRs):
If your audio interface has low round-trip latency, you can setup something very similar using your DAW... and mixIR (plugin).
HeadRush would be played (without Cab Block) into the DAW application, mixIR would be setup with the desired Cab IRs, and you'd monitor the result (in realtime) as you're playing.
You could also setup advanced delay/reverb in the DAW... hearing the final result in realtime.
A side benefit of this is that you'd be recording the dry Amp signal. You could change Cabs and ambiance/EFX at any time.
If you've ever tried running two 2048-sample IRs in HeadRush, that and an Amp Block pretty well maxes out the DSP.
This is a means of working around that limitation.
Best Regards,
Jim Roseberry
www.studiocat.com
jim@studiocat.com
InMusic / Headrush USA
200 Scenic View Drive
Suite 201
Cumberland, RI 02864
United States
Tel: 401.658.3131
HeadRush Canada
1255 Rue Des Artisans
Suite 150
Quebec City, QC
G1N 4T8
Tel: 1 877 981 9910
HeadRush Europe
Unit 3, Nexus Park
Lysons Avenue
Ash Vale
Hampshire GU12 5QE
United Kingdom
Tel: +44 (0) 1252 896040
HeadRush GmbH
Harkortstr. 12-32
40880 Ratingen
Germany
Tel: +49 2102 7402 0
Support: +49 2102 7402 20150
HeadRush Taipei
7th Floor, No. 165, Naking East Road
Section 4
Taipei 105 Taiwan
Tel: +886 2 2717 2389
Fax: +886 2 2717 2734
