HELIX - Patch Viewer for Offline patch info
Started by admin, October 22, 2018, 08:42:13 AM
https://www.thegearpage.net/board/index.php?posts/27367988/
dbagchee wrote>
https://dbagchee.github.io/helix-preset-viewer/
Note: This is very much a work in progress. Currently this tool has the following limitations (for now):
Only displays blocks on the first path of the preset.
Doesn't render correct signal flow or block order.
Lots of missing model data - you will see an asterisk (*) next to items that are not mapped at the moment (though you can still view the blocks parameters and probably figure out which one it is in the meantime).
Some of the parameter data is a little raw (true/false instead of on/off, number formatting, etc).
Could be other bugs!
Source code here: https://github.com/dbagchee/helix-preset-viewer
Alright feel free to give this thing a try:
arkieboy
This could turn out to be really interesting and useful.
I have need of some (offline) macro command functions - I frequently need to switch between multi-out on XLRs for rehearsal to 'everything but guitar' for live gigs.
I'm thinking about an ANT script to convert the JSON to XML and then run an XSLT template across the presets to switch output configurations, but operating on the json directly with javascript makes more sense if you have that skillset - I am an XML programmer in my day job.
It would really help if Line 6 published validator resources so you could check that your transformed files are legal offline - would really help the development of third party tools.
