GT-1000 - 38 second Looper
Started by admin, May 03, 2018, 04:26:09 PM
https://www.thegearpage.net/board/index.php?threads/new-boss-gt-1000-guitar-effects-processor.1905672/page-242#post-26364345
QuoteIs anyone finding the looper's 38 seconds to be insufficient? Is it 38 seconds per loop/layer or is it a total of 38 seconds of recording?
GT-1000 Sound List
https://static.roland.com/assets/media/pdf/GT-1000_sound_eng01_W.pdf
There is one bank of factory patches (P50) which have already remapped CTL1, 2,3 as Looper Controls
I believe it's basically infinite overdubs onto that 38 seconds.  Don't discount that it seems like little memory - you can do a lot with short loops.
Just like the Electro-Harmonix Stereo Memory Man with Hazarai that one had a 30 second looper but you could infinitely overdub on it:
From 2010 when I was using the Hazarai as my main performance looper - probably about eight or ten stereo tracks total (bass, high strings, pads, clean guitar), to make up the bed track then soloing over the top:
lefty Freak
Quote from: admin on May 03, 2018, 04:26:09 PM
GT-1000 Sound List
I also found that when I set up a patch to do this that I didnt need to use up all 3 for the looper because the same button that records will also clear if held down for a few seconds.
"Life shrinks or expands in proportion to one's courage."  ― Anais Nin
mooncaine
All such devices should let you upgrade loop memory with SD cards these days. I like that feature.
Control action when single switch Looper mode is enabled
