Blackaddr Audo Teensy Guitar Audio Shield
Started by admin, May 01, 2018, 10:03:12 AM
http://blackaddr.com/products/
The TGA Pro is the first Arduino compatible audio shield for the Teensy 3.X microcontroller series made specifically for guitarists. Dual-channel in and out means stereo effects are possible along with dual high-impedance 9V preamps. Gain or attenuation of +24dB to -34dB can be applied ensure the best signal level to the ADC. The Arduino/Teensy libaries make it easy to start playing with your own digital audio effects without DSP programming knowledge.
Download the manual,
https://d3s5r33r268y59.cloudfront.net/datasheets/10448/2017-11-10-23-56-32/TGA%20Pro%20User%20Guide_v1.0.pdf
https://d3s5r33r268y59.cloudfront.net/datasheets/10448/2018-02-04-17-43-53/TGA%20Pro%20User%20Guide%20-%20v1.1.pdf
check out the BAGuitar library
https://github.com/Blackaddr/BAGuitar
or PJRC, the home of the Teensy.
https://www.pjrc.com/
This unit is built in small batches and sold on Tindie, check it out HERE.
https://www.tindie.com/products/Blackaddr/arduino-teensy-guitar-audio-shield/
