Boss Tone Central GT-1000
Started by admin, April 11, 2018, 10:03:42 AM
http://bosstonecentral.com/liveset/gt-1000/gt-1000_extra_collection_1/
Live Set
1   BLUESY TWEED   Bluesy crunch sound with a vintage tweed amp. CTL1 adds T-Scream for emotional blues lead.
2   TELEBILLY   Clear-cut crunch sound with sparkling high end and bold low end like Tele best for rockabilly style.
3   FOR SLIDE GUITAR   Clear yet fat drive sound for slide guitar. CTL1 - clean with chorus, CTL2 - boost.
4   E.PF GUITAR   Urban and soulful electric piano sound with panning. CTL1 makes it a bit fusion-ish and CTL2 makes it funky clavi-sound.
5   CTL ROTARY   Modern-vintage drive sound with controllable Rotary Simulator. CTL1 changes the Rotary speed and CTL2 adds Delay & OD like jazz funk lead. EXP controls the parallel Rotary mix.
6   LA TREMOLO WAVE   Drive sound with both digital texture and earthy feeling.
7   TIGHT RIFF   Clear and responsive drive sound best for chicken pickin' style. CTL1 adds more drive for lead phrase and CTL2 adds galloping slap-back delay.
8   IN THE GARAGE   Straight-ahead drive sound for aggressive chord strum for radical garage rock. CTL1 boosts the amp and CTL2 for additional gain.
9   CLASSIC RIG   Simple and expressive crunch sound with Treble Boost. CTL switches add slow modulation like reggae guitars.
10   LOW GAIN RECTI   Add the funky attacks in the rock feeling with the Recti Stack with low gain setting.
*This live set was created with GT-1000.
*These patches reproduce each sound as described above, but not perfectly reproduce the originals.
https://soundcloud.com/boss-corporation/bluesy-tweed?in=boss-corporation/sets/gt-1000-extra-collection-1
http://bosstonecentral.com/liveset/gt-1000/gt-1000_extra_collection_2/
Live Set
1   UNSTABLE & NOISE   Fluctuating pitch and quietly wriggling noise best for ambient/electronica type of long-tone phrase.
2   DIVINE ARP   Clean - light crunch sound with boosted mid yet crispy attack, with slightly modulated warm Analog Delay and Shimmer Reverb producing a magnificent atmosphere.
3   AQUAPLANING   A clean sound with Auto Wah and deep Reverse Delay creating a feeling of floating.
4   SUSTAIN PEDAL   The tones played while depressing CTL1 sustain, like dumper pedal of piano. That enables arpeggio phrases which are impossible with normal fingering.
5   MULTI TAP DELAY   Sequence-like complex combination of five delays. CTL1 adds octave changes in the sequence.
6   SLOWGEAR SHIMMER   An ambient sound with the characteristic attack, deep bass, and floaty pad sound. CTL1 adds two octave higher sound and EXP
7   DREAMING AC RES.   High-definition acoustic guitar sound with spatial multiple delays for folktronica type of music.
8   PANNING PHASER   Huge swelling soundscape with Shimmer Delay and Tera Echo.
9   ST:AW = CTL2>TAP   Expressive clean tone with two Auto Wah set to different rate on an octave lower bass tone for lower strings and string-pad-like Shimmer sound.
10   CRUNCH SPARKLE   Sparkling crunch sound with stereo panning Dual Delay.
https://soundcloud.com/boss-corporation/unstable-noise?in=boss-corporation/sets/gt-1000-extra-collection-2
http://bosstonecentral.com/liveset/gt-1000/gt-1000_extra_collection_3/
Live Set
1   WIDE DRIVE   Wild rock sound with two Brit Stack amps in stereo.
2   LEAD DS OCT/DLYS   Spatial high-gain lead with five delays. CTL1 - clean arpeggios.
3   V-ROCK OD   Overdrive sound with slight modulation and delay for 90's Japanese "Visual Rock". CTL1 adds more drive and delay for lead.
4   A-DIST + CRUNCH   Combination of MDP distortion and amp: A-Dist and X-Crunch for extra clarity and expressiveness. Works well for both rhythm and lead.
5   7STRINGS DS EQ   Heavy , modern pedal-like distortion for down tuning/7-string guitar. CTL1 changes the channel to clean arpeggio sound.
6   ADAPTIVE X-DIST   Stereo lead sound with A-Dist ch and X-Dist ch delivering the significant clarity of MDP technology. CTL1 adds Tera Echo.
7   GOTHIC ARP   Synth-like sound with weak attack and brilliant and thick reverbration for arpegio phrase. CTL1 changes the sound to a gorgeous synth lead with a high-gain amp.
8   PEDAL BEND LEAD   Rich harmonic drive with a pedal controlled octave up with ping pong delay.
9   VOLCANIC PHASE   Classic Phaser Rock tone on the left side. Delay on the right. CTL 1 – Phaser on/off CTL 2 – tap tempo EXP – Delay level
10   FLANGING PAN   Stereo panoramic distortion sound with Flanger.
https://soundcloud.com/boss-corporation/wide-drive?in=boss-corporation/sets/gt-1000-extra-collection-3
http://bosstonecentral.com/liveset/gt-1000/gt-1000_extra_collection_4/
Live Set
1   DOUBLE S-BEND   Control two parallel S-Bands with CTL1, CTL2, and EXP pedal.
2   WALLGAZER   Roaring shoegazer tone with Reverb set at the beginning of the chain and boosted with Compressor and Fuzz. CTL1 changes the amp type for more extreme noise sound. CTL2 adds Delay.
3   SCREAM-SHIFTING   Orthodox drive sound goes crazy as stomping on the CTL switches. CTL1 adds Ring Modulator and CTL2 adds inharmonic tone and Delay.
4   SINGULAR SITAR   Sitar-like ethnic sound. CTL1 makes it more fusion-like drive sound. CTL2 adds Tremolo.
5   MECHANICAL TONE   Very thick octave sound. CTL2 holds the sound and slice it like machingun.
6   MIGHT BE THOR   Massive stereo octaves. EXP pedals for pitch down two semitones.
7   AUTO PEDAL BEND   Aggressive auto-pitch-bend with Slicer. CTL1 adds orthodox lead sound.
8   CTL 2 LOFI   CTL2 adds a metallic noise by Ring Modulator to the rugged crunch sound.
9   ANGRY ALIEN   Let angry aliens babble with EXP pedal control.
10   SLICE'N'DICE   Sliced drive sound in half-note triplets with auto wah.
https://soundcloud.com/boss-corporation/double-s-bend?in=boss-corporation/sets/gt-1000-extra-collection-4
http://bosstonecentral.com/liveset/gt-1000/gt-1000_rock_anthology/
Live Set
1   JOE'S BOOGIE   In the style of "Satch Boogie"
2   4THE LOVE OF STEVE   In the style of "For the Love of God"
3   ISTHENIGHTSTILL?   In the style of "Still of the Night"
4   THE WATCHTOWER   In the style of "All Along the Watchtower"
5   FASTLIFE   In the style of "Life in the Fast Lane"
6   ANGUS IS BACK   In the style of "Back in Black"
7   I'M COMING AROUND   In the style of "When I Come Around"
8   MORE THAN FEELS   In the style of "More Than a Feeling"
9   SWIRLING WING   In the style of "Little Wing"
10   12ST TO HEAVEN   In the style of "Stairway to Heaven"
https://soundcloud.com/boss-corporation/joes-boogie?in=boss-corporation/sets/gt-1000-rock-anthology
mchad
Thanks admsustainiac. Getting a better idea of what the GT1000 can do. Those control switches are cool!
Quote from: mchad on April 11, 2018, 03:52:47 PM
And after Boss Tone Studio for GT-1000 is released in May 2018 , we can use these patches to learn how they employed GT-1000 Control Assignments
Many More GT-1000 patches with Control Assignments listed here
GT-1000 Sound List
https://static.roland.com/assets/media/pdf/GT-1000_sound_eng01_W.pdf
roachone
I thought Boss Tone Central was going to be putting new artist on it. Seems like the same as when it came out.
Quote from: roachone on July 24, 2019, 03:16:10 PM
IMHO Boss Tone Central is not ideal - and remember there is NO capability for real users to share patches there
Thats why we point to these user to user patch sharing resources for latest GT-1000 patches
https://www.vguitarforums.com/smf/index.php?board=266.0
See attached a zip file of bulk of Facebook Group GT-1000 Patches
https://www.vguitarforums.com/smf/index.php?action=dlattach;topic=24568.0;attach=18454
I despise Facebook - but I admit that platform is exploding for user to user file exchange
https://www.facebook.com/groups/BOSSGT100TechnicalTipsAndTricks/files/
roachone
"remember there is NO capability for real users to share patches there " Why in the world did Boss decide that? Weird, but we do have here thanks goodness.
